Easiest way to kill a hard-drive?
Discussion in 'Hardware' started by relix, 20 Jun 2005.
  1. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    make a working windowed hdd and just scratch the fu*k outta the platter with a screwdriver or summat
  2. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    you could have the hdd with (extra curricular things on) on a separate drive. Easiest way to wipe it clean is buy a hdd with glass platers and possibly loosen the screws on it or even remove them and use tape to keep the drive shut. As long as the drive is never opened it should run just fine. If anyone tries to confiscate your hdd open the lid and smash the disks to bits so all data is gone.
    Just keep ilegal crap out of your pc at a public place. I dont condone having anything ilegal on anyones machine so this is only advice for protecting your information from falling into the wrongs hands rather than hiding ilegal data.
  3. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I'd back up all your data and make another partition to use for the LAN party :)
  4. GMan
    GMan Minimodder
    14 May 2004
    It appears that the consensus is that there is no quick way of wiping data while leaving the drive usable.
    Use encryption software: The cops would then be certain you had something really illegal on it and would take the time to get it decrypted, so they could make a headline newsworthy bust. When all they find is a couple of ripped CD's, they'll be PO'd and plant some files on it.....
    Use a laptop drive in a small external USB enclosure. It would small enough to hide, but unfortunately it still leaves rather obvious traces on your system, then you're back to attracting official interest.
    Total physical destruction of the platters really is the only way to ensure the data can't be recovered by someone, somewhere. I'm not talking about simply defacing, bending, stripping, rolling them into a tube, or smashing them, but grinding them into powder or melting them into slag.
  5. John Cena
    John Cena What's a Dremel?
    1 Jun 2004
    Quickly copy a LARGE HUGE file and while it's transfering, pull out the data cable. That should pretty much corrupt the harddisk.
    OR, bend the data cable pins OR shortcircuit the molex connector on the drive by having a SPECIAL molex connector that reverses the power flow.
    That should wipe it out in seconds.
    Heck you can even have a special AMPAGE unit inside your case. The ampage unit will deliver a HIGH power voltage to the harddrive instantly killing it. (240AC right to the molex connector)
    BTW: The idea of Electro magnetism won't work because most of the drives today are ems shielded against small magnetic fields (unless it was a EMS unit which will cost you a billion dollars haha)
    Another way is to get a shotgown and shoot it right in the center. No Evidence, No deal ^_^
    I built a heating unit that heats up to about 80 celcius (haven't measure). It works by having a grid of wires short circuited which heats up the grid. If you could attach the grid to the harddrive, your harddrive would be toast.
  6. relix
    relix Minimodder
    14 Nov 2001
    Some excellent ideas here :D
    John Cena, are you sure that works, the copy-huge-file-pull-plug thingy?
    I also like the DriveCrypt idea, especially since it can hide files and show differint files for differint passwords.
  7. John Cena
    1 Jun 2004
    DriveCrypt is useless.
    When the FBI finds out that you put drivecrypt there, they will take out the harddrives platters, and ignore the masterboot record which holds the password. Which means, they will be able to read all of the data heh.
    I never drived pulling out my data cable but I'm sure it corrupts the data. Even if it's corrupted, the FBI can still recover it using drive recovery tools etc.
  8. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Corrupting the data wont do anything. You need to multi pass zero fill the disc as well, a standard single pass can allow reconstruciton of data fairly easily. 25+ passes should do you, but it'll take many weeks.
    Scratching the platter wont do anything, as the data is stored magnetically. The platters can be removed and the data extracted, even from a heavily scratched disc. Blowing the hdd up might work, but again if the platter/s remain intact theres a chance data can still be recovered.
    Passing a current through the disc might well fry the electrics inside, but again the platters will probably be ok. Encrypting the drive, theres going to be a way to decrypt it, if someone wanted to get the data off they would be able to.
    The only way to safely remove all traces is to incinerate the drive, melt the platters and destroy them. Not something you could do quickly... Though planting a nuclear device under the drive might be one solution for a quick drive wiping ;)
  9. John Cena
    1 Jun 2004
    Highlander is right.
    The Platters must be destroyed. I suggest have a dynomite planted under the HD with a fuse outside the case. As soon as the FBI knocks, light the fuse.
  10. djedditt
    djedditt What's a Dremel?
    18 Aug 2004
    Why don't you just put your illegal stuff on an external HDD and as soon as the cops come just grab your hammer you brought with you and smash that !@#$%F*CKR to junk..? (I mean the HDD, not the cop.. :p)
  11. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    * wonders how to spell paranoia? :duh: :sigh: :wallbash: :sigh:
    you know there is one solution that has probably been mentioned but here goes: just dont get caught!
  12. webbyman
    webbyman Hax.
    7 Oct 2004
    i still think a soft core iron horsey shoe shape would work, wrapped with plenty of coils attached with an emergancy switch :D
  13. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    These suggestions are all very inventive, but a shattered hard drive platter still contains data. A corrupt drive still contains data. The only way to truely remove all chance of recovery is to grind the platter to dust or to use an extremely expensive industrial strength electromagnet. You could always sneak into your local hospital and use the MRI machine :p
  14. felix the cat
    11 Jan 2002
    good idea, but they would not be happy having to splash out another ~28,000 Pounds on new cooling after the scanner had to be shut down....(when metal object are taken into the room of the scanner anything big enough to be attracted by the magnet, and im pretty sure a hdd would fall into this, the scanner has to be shut down...now scanners are not active 100% all the time, but the cooling for the magnets has to kept under a constant charge/energy flow or it is rendered useless)
  15. DeathAwaitsU
    DeathAwaitsU I'm Back :D
    27 Feb 2004
    DriveCrypt Plus! then, it makes encrypted volumes that you have to mount once your in the os.
    Death
  16. TMM
    TMM Modder
    12 Jan 2004
    lmao that would be funny.
    "whats the microwave for?"
    "wiping my hdd"
    ":eyebrow:"
  17. felix the cat
    11 Jan 2002
    microwave + metal object....yep great plan! :|
  18. DeathAwaitsU
    27 Feb 2004
    Well it would kill the hd..... most probably yourself as well tho :hehe: .
    Death
  19. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Laptop drive in a wee caddy. Cops come by, down the pants she goes ;). Make it USB for bonus points.
  20. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    It depends on how interested the cops are and how paranoid you are, if you'd rather break your hard drive, or encrypt it. If any of you saw what happened with the thermite hard drive destruction, there was a huge plume of black smoke, and much of the case melted - not something to do indoors. One option might be a degausser sitting on top of the disk.
