Overclocking Easiest way with i5 2500k
Discussion in 'Hardware' started by AoE, 18 Feb 2012.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    Similar to AMD O/Clocking?
    Plus wonder if you guys can help me out, i switched from an AMD setup/windows and upon boot up with the new i5, sometimes it brings up a message, failure to load or something, then says about the cpu may have been overclocked or overvolted, press any key to continue. any ideas
  2. Uxon
    Uxon Minimodder
    14 Dec 2010
    Would be useful if we could have the exact error message, however K-series overclocking is pretty straight forward (like AMD black edition) overclocking on most motherboards as you usually just need to change the CPU multi and maybe bump up CPU core and CPU VTT voltages a little.
  3. Instagib
    Instagib Minimodder
    12 Mar 2010
    When you oc a i5 2500k, you set the turbo boost multi, so that when the chip is under load, the chip boosts it's clock to 4.5+ ghz (100*45).
    Just like Uxon said, it is alot like the AMD BE chips when you leave cool and quiet on.
  4. AoE
    4 Oct 2011
    The random message I get upon booting the pc is:
    Not sure if this has any thing to do with it, but I forgot to connect one molex from the H80, started up the system but checked CPU Temp in bios and it was 85c because there was no cooler. Would this have damaged the CPU? it was only on for no more than 2 mins.
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Possibly, depending what temperature it actually reached and how long it stayed there. Have you changed any settings in BIOS at all?
  6. K404
    K404 It IS cold and it IS fast
    11 Sep 2006
    I doubt the chip is badly damaged....though you were sailing close to the wind......
    I don't have tons of SB experience but I always found it to be a bit random in booting with an OC. Maybe a voltage is too low?
  7. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    When I overclocked my CPU, the max voltage I put through it was 1.35v Now this happily hit 4.5ghz and at one point his 5ghz but now it just wont get there. BSOD's above 4.5ghz.
    I don't OC anymore I did it just to see if I could. I don't need that extra CPU grunt.
    And what people have said before is correct. Increase the Turbo Multiplier to achieve the OverClock.
  8. Instagib
    Instagib Minimodder
    12 Mar 2010
    I've noticed that with mine; 1st few times, mine would hit 4.8Ghz @1.45V (crappy chip) Now it struggles with 4.5Ghz @ the same voltage. Now I just leave it at stock as all the games i play rarely push it. I'm actually contemplating going back to my trusty AMD rig as that was never really pushed but is alot quieter (water cooled).
    I wonder if we're seeing chip degrading at a quicker rate due the higher voltage to transistor size ratio?
  9. AoE
    4 Oct 2011
    Ived changed the multipler a few times now but wont save the settings when I get to desktop for some reason. I dont have a turbo multipler just a normal one ?
  10. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Not sure with Gigabyte Mobo's bit with Asus it's the turbo multiplier that's changed. And as to why the settings aren't being saved i don't know why either.
  11. AoE
    4 Oct 2011
    I reset the cmos battery and saved new settings but under "my computer" the changed settings are not taking effect, maybe I am not changing something else?
  12. jizwizard
    jizwizard Modder
    24 Dec 2010
  13. AoE
    4 Oct 2011
    hi CPU-Z is showing updated settings of OC but mycomputer is'nt is this a reliable indicator of this?
  14. GeorgeStorm
    16 Dec 2008
    Haha, ignore my computer.
    Just use cpu-z.
    SB is easy enough, up the multi, when it's no longer stable, up the vcore, then up the multi again and so on ;)
  15. AoE
    4 Oct 2011
    Just done 3.7ghz on stock vcore, ran IBT for 10 packs @ very high (5gb ram), max temps were 61c but average was around 56/7c and found to be stable. any issues with temps?
  16. K404
    11 Sep 2006
    IMO, that's a bit high?
  17. AoE
    4 Oct 2011
    You sure? just did the same test on 3.9 and more or less the same story with max temps reaching 64c but not for more than a minute then decreasing again
  18. feathers
    feathers Minimodder
    11 Apr 2009
    56c isn't great for 3.7ghz with a liquid cooler.
    Does the cooler have good thermal paste? Did you touch the thermal pad or cpu surface with your finger which may have contaminated it?
    Is the cooler fitted properly (screws tightened assuming it uses those).
    The other thing is if your H80 rad is sucking air from inside computer case, that will be pre-heated air. Heated by the GPU, Ram and PWM, what is the airflow like in your case?
  19. AoE
    4 Oct 2011
    its at 4ghz now and idle temps are:
    cores 1-4 (31/29/32/33). The H80 is using air from within the case and the case is a Raven RV02, I might change to a push pull config. I didnt have much thermal paste left and only applied what I had, as for touching the CPU, the surface?
  20. feathers
    feathers Minimodder
    11 Apr 2009
    Idle temps ok, what are load temps now?
    Yes, the cpu heatspreader.
