Guide Easy HDD-cooler
Discussion in 'Modding' started by Jipa, 20 Apr 2005.
  1. Jipa
    5 Feb 2004
    It's been a long time, but finally I'll answer to question :D
    I've so far caught all my heatsinks for free.. They just lay around in large piles ;) All kinds of junkyards are best places to find heatsinks..
  2. Ener
    Ener What's a Dremel?
    17 Oct 2005
    hey, nice mod but my computer case is to small to do that lol (im so poor)
  3. mattthegamer463
    26 Nov 2004
    interesting mod. does it signifigantly cool your hard drive? also, whered you get that huge heatsink?
  4. Tibby
    Tibby Back Once Again
    9 Oct 2005
    You got the massive heatsink from a chair?
  5. Skylined
    Skylined Minimodder
    3 May 2003
    Tibby: I think that the huge heatsinks you're talking about aren't the ones I've used but the ones Jipa used.
    And mine, yes, from a beach chair, they were the armrests
    mattthegamer463: in my case it does, and you can feel the heat all over those aluminum bars.
  6. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    I would have at least a small gap between the HD and the PSU, as it should make it a bit cooler.
  7. Den-nis
    Den-nis What's a Dremel?
    3 Nov 2005
    Why don't you re use some old Heatsinks with fans.
    And just attach them to you Hdd ?
  8. Skylined
    Skylined Minimodder
    3 May 2003
    Right now I have a ghetto setup, and my HDD is much cooler, I had it very close to the mobo tray.
    I've reused arm rests :p
    And fanless is better, no noise at all. ;)
  9. slytherock
    slytherock What's a Dremel?
    10 Jun 2004
    I've done that a couple of years ago, but with a little difference.
    The use of rubber decrease the vibration, so it reduce the noise level.
