Motherboards EATX12V / EPS12V question
Discussion in 'Hardware' started by cragside, 30 Apr 2009.
  1. cragside
    cragside What's a Dremel?
    30 Apr 2009
    Hi,
    bit new to the intricacies of PSUs so hope you can help
    my new Asus P6T Deluxe v2 motherboard has an 8-pin EATX12V connector, into which I am supposed to plug either a 4-pin or 8-pin plug. It says I should use 8 pins in order to overclock a core i7 CPU.
    However my new Corsair PSU has an 8-pin EPS12V, which can be split into two 4-pins. The Corsair manual says if the mobo has 8-pins then plug the whole thing in. The problem is the shapes don't match up. If I split the plug in two, I can match up the four right-hand pins on the mobo.
    The thing is, the whole 8-pin plug does actually fit into the socket because the curved plugs fit inside the square plugs. It just seems wrong though, and the manuals don't seem to mention specifically connecting an 8-pin EPS12V to an 8-pin EATX12V.
    Will I get the full 8-pins worth of power?
    thanks
  2. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    Yes the plugs are not perfectly snug fitting, but they will provide full power.
  3. cragside
    30 Apr 2009
    phew, thanks mate
