News ECS tips hat to X58B-A Black Series
Discussion in 'Article Discussion' started by CardJoe, 29 Oct 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    I like the colour scheme...
    The single molex over by the PCI-E connecter is instant fail though. There must be a better way than draping a cable all the way across the mobo like that...
  3. Mentai
    Mentai What's a Dremel?
    11 Nov 2007
    It looks like a good board, I know a lot of people who would buy something like this. The types that think they might want SLI/crossfire or more ram in the future, but are probably never going to overclock or use extra mobo features. As long as it hits the right price point...
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    When will we see a full review of this?
  5. salesman
    salesman Minimodder
    29 Apr 2007
    No floppy or ide?
  6. Cobalt
    Cobalt What's a Dremel?
    24 Feb 2006
    Looks like it, which is a welcome development.
  7. Guest-16
    Guest-16 Guest
    Good spot :thumb:
    Probably, if they sell it in the UK.
  8. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    ill hold my judgement till the reviews r out.
  9. phuzz
    phuzz This is a title
    28 May 2004
    Does anyone actually use dual-NICs outside of a server environment?
  10. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    At least they got the guts to ditch the FDD and IDE connectors. This saves controler hardware and connectors. To bad they didn't extend the sata range to 8 or 10.
    It probably will be cheap(er) then the rest of the bunch although we must see the AsRock x58 boards first. I guess for normal operations it will be good enough.
  11. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    just out of curiosity: is this the first mainstream board to do this? In that case, WIN!
    Too bad about the failplug by the PCI, and that Qooltech sticker just gets the kill.
    Then again, i like the color scheme, and the simple approach is also nice.
    I'd have to see how it performs :p
  12. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Not a lot of black on that motherboard... yeah know... being a "Black Edition" and all, I figured it'd look mean and angry like the Foxxconn Black Ops. Instead I was greeted with a colorful rainbow. Doesn't look all that interesting, and *only* $260? I think I'd just pickup a P45 or a P55 board for around $200 and get all the fancy pants power regulations, flux capacitors, 1.21 gigawatt power regulators, hyper-space drive, dilithium core, and light saber holster all in one, from the likes of Asus or Gigabyte.
  13. ChaosDefinesOrder
    6 Feb 2008
    one ethernet cable to a broadband connection, the other to a laptop (either yours or a friends).
    This is especially handy at university where you don't have a router/hub, only a single network port on the wall - if you want to quickly transfer stuff between your PC and a friend's or your own laptop, an ad-hoc gigE is about the fastest way of doing it.
  14. tuaamin13
    tuaamin13 What's a Dremel?
    27 Apr 2008
    It might not be that bad though. What you could do is run the molex down the side of your case on the case window side (since everyone has case windows), but tuck it more towards the edge (since most case windows aren't pure plexi, so they have a bit of a frame). You'd have to have some extra slack though to open/close the case enough for you to secure/unsecure the wires, but if you don't open your case too often it won't be horrible.
    It might also be possible to get the cable under the motherboard, and come up near the PCIe slot, but that's really dependent on your motherboard tray and the stuff you've got plugged into the board.
    I agree though, I dislike these extra power connector requirements. At least put them near an accessible edge of the board.
  15. Guest-16
    Guest-16 Guest
    It's not a requirement - the molex is entirely optional. Just don't use it.
Tags: Add Tags
