Hardware Edimax EW-7438RPn Wi-Fi Extender review
Discussion in 'Article Discussion' started by brumgrunt, 20 Feb 2013.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Woodspoon
    Woodspoon What's a Dremel?
    10 May 2008
    This looks quite useful, could do with one of these to sort out the poor reception spots.
  3. phuzz
    phuzz This is a title
    28 May 2004
    Something like Wifi Analyser can be pretty handy for working out the signal strength is different rooms, and for working out which channel(s) to use that aren't being used by your neighbours.
  4. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    Although I personally wouldn't game over wifi unless my network port dies, can you say what happens to your ping through one of these?
    I am assuming it would have to increase, as there is another "hop" involved. But I wonder how much by?
  5. mute1
    mute1 What's a Dremel?
    16 Sep 2009
    Correct me if I'm wrong but isn't there a flaw in WPS that makes it insecure? In which case, the manual route is the way to go (even if that does sound paranoid - better safe than sorry when it comes to a couple of minutes' effort).
  6. forum_user
    forum_user forum_title
    4 Jan 2012
    Antony, can more than 1 of these units be used to stretch coverage across larger areas, and does using more units reduce the speeds?
  7. Bokonist
    Bokonist What's a Dremel?
    2 Mar 2011
    You are right, WPS intorduces a vulnerability that can allow someone with just a little knowledge to hack your WPA pass key. Unfortunately turning WPS off doesn't stop the hack from working, so if you're unlucky enough to have a vulnerable router then using this device will neither decrease or increase your security. If one of these will help your situation then get one. The only sensible defence against the WPS hack is to either update your firmware to a non vulnerable version, and/or make sure your wireless key is at least 25 characters long. This means that the hack is still technically possible, but would take a prohibitive amount of time to work.
  8. David Wakeman
    David Wakeman What's a Dremel?
    19 Dec 2013
    I cannot find any reference in the reviews or product descriptions to the LAN connection (other than it is a CAT5 interface). I understand this is used for setting up, but having completed the setup can it also be used as a normal LAN connection to other non-wireless devices?
Tags: Add Tags
