Anyone have any experience with this adapter I only have a spare PCIe 1x socket left. Edimax EW-7612PIN 300Mbps Wireless PCI-E Adapter Any advantage over this one in a normal home wireless network? TP-Link TL-WN781ND 150Mbps Wireless Lite N PCI Express Adaptor - TL-WN781ND OS is Win 7 64 bit Thanks Simon
Just bought the Edimax myself Great wi-fi adaptor, very popular. If you have a network capable of channel bonding, the Edimax is the one to go for. Otherwise, there isn't much point in spending the extra money for it.
Simply install the driver off the CD, and that's it, use as normal Of course, if you have other wi-fi adaptors, uninstall their software, then if they're still appearing in "Manage network connections", go to there, right click on the old adaptor, Properties, Configure, Driver tab, then uninstall the driver
Many thanks As an update the Edimax is excellent and comes highly recommended, it is both very easy to install and configure
