Cases Edit: Nwm dont think its a problem
Discussion in 'Hardware' started by Mech0z, 2 Apr 2009.
  1. Mech0z
    Mech0z What's a Dremel?
    27 Mar 2009
    For once I accually like what I see from TT which is pretty rare. But this case looks pretty decent for good airflow http://uk.thermaltake.eu/product_info.aspx?PARENT_CID=C_00001397&id=C_00001398&name=Element+S&ovid= and the price is very nice as well. And it does look A LOT better than the HAF 932 which looks like a crane imo.
    But Do you think I can fit my Scythe Mugen II in with that 230mm fan on the side?
    The Element S would be the same I guess.
    Edit: Think its not a problem as they are installing a True black here http://www.driverheaven.net/reviews.php?reviewid=730&pageid=4 and if that can fit then my Scythe can fit as well
  2. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Bad link for me.
    AFAIK most TT cases are pretty huge, and you should be able to fit the cooler in, it's only 120mm fan size. Should be fine :)
  3. Mech0z
    27 Mar 2009
  4. Guest-23315
    Guest-23315 Guest
    ^^ Thats one of the first Thermaltake cases that I wouldn't actually mind owning.. :thumb:
  5. Mech0z
    27 Mar 2009
    Year it looks quite decent even though it aint alu. Just wonder what the price will be here in Denmark, and I hope you can turn off the light on the top fan.
