News Eee PC warranty still intact
Discussion in 'Article Discussion' started by Tim S, 10 Dec 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Very nice mod! I would run an extern 2,5" hdd instead as my soldering skills are far from enough for a mod like this :duh:
  3. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    what about changing the hard drive? and the battery?
  4. antiHero
    19 Jan 2005
    The EEE doesnt have a harddrive as it uses flash chips soldered to the motherboard as storage.
  5. airchie
    airchie What's a Dremel?
    22 Mar 2005
    Totally sweet mod, I love it!
    I want to do it now. :D
  6. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    I don't really understand the desire for these things...
  7. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
  8. specofdust
    specofdust Banned
    26 Feb 2005
    ****ing awesome :D
    I'm gonna open up my wee precious right now. DXR - you'll be able to add a Mini-PCI-E based HDD, but it replaces the internal SSD aparently, so if you stick an 8GB one in then you lose the initial 4GB. A little annoying. In a year or two though if say 32 or 64GB mini-PCI-E based SSDs were cheap, it'd be a great upgrade. As for the RAM, that's getting done ASAP on mine.
  9. capnPedro
    11 Apr 2007
    I was thinking of waiting till the price comes down, then picking up a black one, vacuum forming some clear acrylic, doing an etching, LEDs, an iPod HDD, internal Bluetooth. Possibly expand the battery capacity. Custom kernel and window manager etc. Really pimp one out. Like really ridiculously.
    You know, because I can. And have an uber portable machine. Oh, and get mod of the month ;).
  10. specofdust
    specofdust Banned
    26 Feb 2005
    You're very unlikely to find space for that in the current casing. The new 1.2" drives toshiba released though? They're a strong candidate for fitting in the physical space above the RAM. You can also do internal blootooth very easily. Battery capacity is harder, although people have started investigating the possibility of building their own cells. It won't be long before uprated cells are out there. Overclocking is fairly simple too, straight to 900Mhz. Further if you're lucky/crazy.
  11. knuck
    knuck Hate your face
    25 Jan 2002
    aren't you guys annoyed by the fact that the screen is not 'fullscreen' (black plastic borders)
    or is it just me ? :D
  12. capnPedro
    11 Apr 2007
    I've seen a Bluetooth dongle and flash drive added, so I know that's definitely possible. The plan was to vacuum form a new cover not only to give me a window, but a few extra mm for either the HDD, or a USB WiFi dongle (so I can put the HDD where the internal WiFi card is; next to the PCIe slot).
    And I've swapped laptop battery cells out before - just buy higher capacity ones, and tweak the charger a little.
    Overclocking? of course. I'm crazy!
  13. antiHero
    19 Jan 2005
    Its been done! Cuts down on battery life hard but not impossible. Check it out here!
  14. specofdust
    specofdust Banned
    26 Feb 2005
    Wow, I can't believe I missed that. I browse those forums every day for new stuff on my little box of tricks :D
    It's a fairly extreme mod, but damn that's cool. Of course, modding in the 1.8" SSD's that are just around the corner, in very large flavours, will be far far more interesting.
  15. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    sweet :thumb:
    great mod
  16. chrisuk
    chrisuk What's a Dremel?
    23 Jun 2005
    I've got one on order, for later this week. I think, for my commute in the morning, its a bit of a bargain really. Nice and hackable as well. The closest thing I've seen over here (uk) is the N810 which is about £100 more expensive. And well, here you are probably looking at a similar step up to a basic laptop (unlike the US) - plus, if I wanted to take a 15.4" laptop on my commute, I'd take the MBP.
Tags: Add Tags
