Does the EeePC version of Linux come with gcc or some other compiler and if so how do i use it? If not how can i install one (preferably gcc)? Thanks
It's a standard X86 CPU. http://en.wikipedia.org/wiki/List_o...othan-512.22_.28ultra-low-voltage.2C_90_nm.29
Glider, when i used that command it gave me the following error message: "Package gcc is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only availabe from another source E: Package gcc has no installation candidate" What should i do?
That's because debian has a fancy naming for gcc... Try what steveo said, it'll install an entire compile environment
Might be a lack of decent repositories. Check the Eee wiki to find out how to add some extra xandros ones, and to learn how to add debian ones and pin them so that you don't break too much stuff.
