Effective Overclocking
Discussion in 'Hardware' started by G4m3R_X3r0, 16 Feb 2007.
  1. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Ok so I have an AMD Athlon 64 3800+ Venice Core.
    It's currently running on the BFG Nforce4 Ultra Board with 2gigs of PC 3200 Ram.
    Here is my question, I know about overclocking, but is there a good effective way of doing it. Example being:
    Proc. speed = higher clock cycle + lower multiplier
    or
    Proc. speed = lower clock cycle + higher multiplier
    Also figuring voltages in to that equation.
    On another side note, could some one please explain the what CAS latency is and how it works per say, or if there is any place out there where I can read up and educate my self.
  2. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    google is your friend
  3. nazomcg
    nazomcg Minimodder
    4 Aug 2006
    In general having a lower multiplier and higher fsb will result in more performance, the reason being the higher fsb speeds up more than just the cpu, it also increases bandwidth for data transfer across the chipset. However, you may find that your motherboard is the limiting factor in the overclock because it cannot support the high fsb's you want, if this is the case then you may have to fall back on upping the multiplier.
  4. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
  5. G4m3R_X3r0
    3 Sep 2004
    You da man Pie! thx! BOOKMARKED!
