Efficient Power Supply?
Discussion in 'Tech Support' started by Revenant, 2 Feb 2007.
  1. Revenant
    Revenant What's a Dremel?
    2 Feb 2007
    Hi guys, I'm about to build a new rig, and was hoping for some advice
    I am going to be using an 8800GTS, and will not be overclocking the rig
    The 8800 GTS requires ones PC to have a minimum 400W at 12V|26A
    The powersupply i wish to use is 500Watts, +12V1|16A and +12V2|17A
    it has 2 gigs of ram and only one 8800GTS and again will NOT be overclocked
    will this powersupply work?
    thank you :)
  2. Dustin
    Dustin What's a Dremel?
    22 Apr 2006
    What brand is that?
    It looks it will hold it up
  3. Revenant
    2 Feb 2007
    it looks like the brand is NZXT. It comes with the case, and the combo is pretty expensive so I expect somewhat of a sturdy powersupply
    and wow thank you for your speedy reply! :)
  4. Dustin
    22 Apr 2006
    NZXT stuff is cheap.It might hold up (i wouldnt bet) but if you have some extra cash to spare go for Corsair 520W - very good psu and good price.
