Hi guys, can anyone tell me the dimensions of a 1046 with barbs on please... If you can also give me an idea of height with 6mm ID tubing attached too, it'd be a great help. I've only got ~14cm to play with in the bottom of my case, so I'm investigating whether I've got to start networking hard drives n schitt Thanks
Hi, I have the 12V version of the Eheim 1046 - which I intended to run in series with my old EXOS to cool my SCSI drives. Just measured the pump for you - 7cm height (pump alone), 12.4cm length, 7.5cm width. These include the side fixings in width, and the length counts the front point of the impeller as the end. I can measure differently if it will help. Just sitting here next to the ruler! Hope that helps
Happy to try. To be honest, I had only just decided to use the pump with the EXOS. The top hole (outlet) has a smaller diameter...is it 1/4"? I will try to see if I have the correct barb already. I know I have the barbs for the 1250's I have...but not the smaller sizes.. Just found the correct Innovatek outlet barb. I fitted a brass 3/8" to the suction side. The measurements: Length - 16.6cm Height - 9.2cm
