Cooling Eheim 1048 Noise
Discussion in 'Hardware' started by aggallim, 12 Nov 2003.
  1. aggallim
    aggallim What's a Dremel?
    12 Nov 2003
    Hi,
    I've had my eheim 1048 for about 18 months and all of a sudden its started making a worrying rattling noise.
    I took it to bits once which helped for at least 5 mins before making the noise again. Anyone had this problem and know a fix?
    Thanks
    aggallim
  2. Darv
    Darv Bling!!
    12 Aug 2002
    Noise in the pump usually means you have air in your system. I would try re-filling it.
    It could be something else like your pump being worn out etc
  3. aggallim
    12 Nov 2003
    I've re-filled it twice now with no luck.
    I read somewhere that there are some platic blocks holding the ceramic shaft in place, does anyone know anything about them and if they can be replaced?
    Thanks
  4. Guest-16
    Guest-16 Guest
    take it out and clean it, then check the mechanism is working with no errosion etc
  5. chadwick
    chadwick What's a Dremel?
    2 Oct 2003
    take out the impeller and super glue the two pieces together
  6. Sylix
    Sylix What's a Dremel?
    14 Sep 2003
    try this eheim-mod
    with the time the ceramic axle starts to be worn out itself and creates a recess(?) , that starts to make noise.
