Cooling Eheim 1250 from aquaticsonline.co.uk
Discussion in 'Hardware' started by Theo, 12 Aug 2003.
  1. Theo
    Theo What's a Dremel?
    12 Jun 2003
    Hello, I ordered this pump yesterday as part of my plan to beef up my watercooling rig.
    Could anyone tell me what I might need to incorporate it into my set, and where I can get these items from, please? I'd like the push to be 12mm and the suck to be 10mm, but I'm not sure which barbs to buy.
    Thanks
    Theo
  2. chill-tek
    chill-tek What's a Dremel?
    18 Nov 2002
  3. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Hi Theo
    for the outlet you will need 3/8" BSP thread to 1/2" hose tail but for the inlet you will need a 1/2" BSP thread to 3/8" hose tail.
    /........not sure why you would want the inlet to be so small though as you will be restricting the flow of the pump quite a bit with that size barb......you would have to get it special order as well from somewhere.
    for the outlet try 3/8" BSP to 1/2" hose tail if you wanted brass.
  4. coolmiester
    31 Dec 2002
    Neither is chill-tek by the looks of it :duh: think he's getting his BSP thread sizes a little mixed up :nono:
    /..........you might want to amend your site also :wallbash: :D
    The thread size on an Eheim 1250 inlet is 1/2" BSP and the outlet is 3/8" BSP
    and
    an Eheim 1048 inlet is 3/8" BSP and 1/4" BSP outlet
    :naughty: :D
  5. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Hey guys, can we not have the 'Pimp off'. By all means give the guy some advice but let's not turn it into a sales pitch.
    Now, I have some barbs which'll fit that you can buy.. ;) j/k
  6. coolmiester
    31 Dec 2002
    maximum sorryment ::kna::
    consider wrists slapped..........won't happen again :nono:
  7. chill-tek
    18 Nov 2002
    Hey Kna. Please accept my sincere apologies for the content of my previous post. I'm sure you are fully aware this is not at all our style.
  8. Theo
    12 Jun 2003
    Thanks chaps, quite helpful there :)
    I wanted to use 3/8" because I didn't really fancy changing my cpu block. I bought a waterchill kit a few months ago, and the outlet from the block is 10mm (if I remember correctly, anyway...). I'm having alook at a few other waterblocks at the moment now, so the pump barbs will wait until I've figured that out.
    Thanks again, you gave me a good slap in the face and woke me up a bit about the flow :>
  9. Theo
    12 Jun 2003
    By the way, chill-tek, your site doesn't seem to be working at the moment? (00:43 - 13/08/03)
  10. chill-tek
    18 Nov 2002
    Thanks Theo.
    Seems fine today. Wasn't able to check last night mate... in the land of nod.
