News EK Velocity sTR4 series water blocks will definitely be compatible with AMD TRX40-based motherboards
Discussion in 'Article Discussion' started by bit-tech, 2 Dec 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Socket compatibility isn't a big deal, but die compatibility is. Wind the way-back machine back to the launch of Threadripper, and you'll remember the initial TR4 waterblock release was pretty dire, due to AMD supplying OEMs with the physical specs of the socket and IHS but not of the die layout leading to waterblocks that did not actually over the die area (where the heat is emitted). As the Zen 2 Threadrippers feature a different die layout to the Zen 1 Threadrippers, coverage is again a concern.
  3. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    EK in particular had poor performance, using the same size fin area as their 115x and am4 blocks and just extended the cooling plate. Took them 2 further attempts to get it right.
Tags: Add Tags
