Case Mod - In Progress [EK-Vulture]-------Gold Wings--------
Discussion in 'Project Logs' started by snef, 7 Feb 2015.
  1. snef
    snef What's a Dremel?
    18 May 2014
    Thanks guys
    yes they still work really great, the plater guy told me no issue at all,
    the seal can handle more than 60C
    I will put them underwater before final installation
    yep 1/50, really lucky
    Derick told me they keep the 0/50 at head office in Slovenia
    some told me to not mod it, to late :D
  2. snef
    18 May 2014
    Update:
    Waterblock are now assembled
    just love the finish
    gold Screew are on order but not sure if i will swap black for gold,
    a smart guy told me
    :smile:
    im agree
    i will see when i have gold screew
    now some pics
    i received a bonus with my blocks
  3. snef
    18 May 2014
    Thanks guys
    first try on SSD for Gold Wings
    I will try some others design but I really like this one
  4. snef
    18 May 2014
    UPDATE:
    Hanoverfist sent me some photos of the case with paint job done
    like usual, he did a stunning work
    I'm just so impressed and excited
    cant wait to have this case in my hands to start it
    now under normal light
  5. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Not much needs to be said, other than this: :jawdrop: :jawdrop:
  6. aksys
    aksys What's a Dremel?
    5 Jan 2015
    nice stuff indeed, and this mod gotta be so cutie...I am particulary amazed by the gold plated work!
    Is that real gold plating???? or just a nickel plating? I guess that gold plating would be so expensive...
  7. Bradley8988
    Bradley8988 What's a Dremel?
    16 Jun 2008
    Case and idea looks great. How much was the plating?
  8. Cheapskate
    13 May 2007
    Love that paint.:D
    Ok, I haven't seen any radiators yet. I have a sneaking suspicion they won't go in the case black. The question is, are they gold flake, or full-blown plated?
  9. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Snef, put up the links to the GPU back plates. You missed those on this forum. :) SO bloody epic, those things!!!
  10. snef
    18 May 2014
    Update:
    its the Egyptian Vulture Goddess her self
    Nekhbet
    @cheapskate
    sorry, no flake or gold plated, didn't find a place who can plate aluminum, and not sure about gold anodized
    paint it and add a little touch
    some pics of Fan et Rad assembled
    added some hieroglyphs for test and finally I will keep them , I like it a lot
    received the case today
    honestly , you need to see it in real, its far better than on photo
    Hanoverfist did a awesome paint job,
    did the first test fit,
    still have some work to do on GPU and Motherboard
    and I will remove all black screw inside for gold screws
    and not happy with tubing, I will do more bend instead angle fittings
  11. bulldogjeff
    2 Mar 2010
    This is a seriously good looking build, love the color scheme.
  12. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Very nice!
    But it's a shame the ssd's are hidden away
  13. Bygone
    Bygone Minimodder
    15 Apr 2015
    Looking forward to seeing more of this build, great Work as always snef
  14. snef
    18 May 2014
    Thanks
    Storm-83, youre right, I moved them to a better place
    Update:
    start the sleeving and cabling today
    and I relocated SSDs
    Sleeving and Cables combs are from Darkside
    http://www.darksidemods.com/index.html
    [​IMG][/url]
    [​IMG][/url]
  15. storm-83
    storm-83 Minimodder
    7 Nov 2014
    "It's beautiful!"
  16. Hukkel
    Hukkel James' minion
    20 Dec 2012
    That is a very nice and clean theme.
  17. Impeccable Logic
    Impeccable Logic What's a Dremel?
    9 Mar 2015
  18. rakesh_sharma23
    rakesh_sharma23 Minimodder
    2 Sep 2007
    Great build.. those hieroglyphs looks awesome,, Just one more suggestion have a Sphinx picture on the PSU side or anything like that .. PSU seems little empty..
  19. snef
    18 May 2014
    Thanks
    Update:
    I think I found a way to not have all white coolant and reservoir,
    i just like it
    can still see the liquid level
    what do you think?
  20. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    :jawdrop: Snef, I love you. No homo. :D Those reservoir sleeves look AMAZING, as does the rest of this build!! :rock:
