Blogs EK Waterblock on the Radeon HD 5870
Discussion in 'Article Discussion' started by Cutter McJ1b, 4 Dec 2009.
  1. Cutter McJ1b
    Cutter McJ1b Home-cut jibs at discount Prices
    18 Feb 2009
  2. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Surprisingly basic design, though it should allow for high flow rates.
  3. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    What do you mean "Do NOT use them"?
    You mean until after you've cut the right shape out?
    Otherwise you've said do not use them, then used them anyway.
  4. Guest-16
    Guest-16 Guest
    Sorry I had a massive brain fart. I meant you MUST use them. It's been changed. :thumb:
  5. dec
    dec [blank space]
    10 Jan 2009
    really pretty block. with some UV active water itd be the fastest and coolest looking card on the market
  6. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    are there stand-offs on the block?
    Your volt tweak could come from the fact of overtightening the screws and thus bending the card - and that would play havoc with your tweaks.
    IMHO all blocks should come standard with stand-offs to prevent overtightenning especially when you slap them on a rare and/or expensive card.
  7. Combatus
    16 Feb 2009
    True, I've killed two cards by blocks either flexing the PCB too much or fouling something creating a short circuit. Some extra support would be a great idea given that your average person's GPU is the most expensive bit of kit in their system.
  8. s3v3n
    s3v3n MMO Cold Turkey -fail
    23 Jun 2008
    I don't like using screwdrivers for heatsinks. I usually screw on things with just the screw bit. That way I can't apply too much force. Tighten the screws around the core with a fair amount of force with thumb and index finger tips. The rest I just tighten down enough to get secure contact . With heatpads, you don't get any more cooling by getting it too tight anyways.
  9. Rocket_Knight64
    Rocket_Knight64 Minimodder
    12 Feb 2009
    As nice as it is, nickle plating can only make it look better against the black PCB. More so with dyed water. :D
  10. Guest-16
    Guest-16 Guest
    Yea I admit it's pretty easy to REALLY tighten the chunky screws.
  11. Squallers
    Squallers Meat Puppet
    7 Oct 2008
    pure guess here and you may have tried it but could it be that the voltage tweak app wont work unless it thinks something's connected to the card's fan header to make sure you don't brick your card?
  12. vampalan
    vampalan What's a Dremel?
    18 Jun 2003
    I was going to say the same thing, so that would be it.. how about dangling the fan on there and see what happens?
  13. Guest-16
    Guest-16 Guest
    I've taken it all apart now sorry, but it's worth keeping in mind for the future! Thanks!
  14. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    ya the Nickel plated blocks are just gorgeous. My second 4870 is starting to act up so Im going to take a part the block and remount it to see if there was something causing issues >< maybe the excuse I need to look into upgrading my cards lol.
Tags: Add Tags
