Watercooling EK Waterblock warning on water
Discussion in 'Hardware' started by Bitwacker, 30 Dec 2012.
  1. Bitwacker
    Bitwacker C# forever
    9 Nov 2009
    I have bought a number of EK products, this time around a got a warning notice. Saying in essence "Use EK cooling liquid... or else". Also, even distilled water is not good enough. I had been running my loop on medical-grade distilled water for years.
    Do we agree?
  2. Tangster
    23 May 2009
    Wasn't this put in after that fiasco with their nickel plating? Either way I use normal distilled water with some UV blue dye and corrosion inhibitor. No problems.
  3. Parge
    16 Jul 2010
    Yes! Don't use distilled water, as it corrodes the nickel plating. Happened to my GTX 480 blocks. Now I just use coolant.
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    It's pretty terrible if they still can't get the process right. Water should never destroy plating that way. They should either fix the problem or stop making it.
  5. Dopeyman
    Dopeyman Minimodder
    10 Jan 2011
    Are you kidding me?! I've got supreme hf and two universal vga ones. Running mayhems distilled and their additive. Does that mean I need to change asap?
  6. Parge
    16 Jul 2010
    Do you use any anti corrosion additives? If so, you are probably ok, if not, then perhaps yes.
  7. Dopeyman
    Dopeyman Minimodder
    10 Jan 2011
    By the looks of it no :( silver coil and mayhems biocide are in it. Oh well another thing on the list to do.
  8. bulldogjeff
    2 Mar 2010
    Easy answer.. They did have a few dodgy batches about 18 months ago and they fixed it. My blocks were from just before it all went a bit pear shaped. I have always run my system with distilled water and little else apart from some UV dye and I haven't had any problems.
    As far as I know the newer stuff is as bomb proof as the older gear is.
  9. Parge
    16 Jul 2010
    So why are they still shipping blocks with warning notices?
  10. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    It's probably to cover their balls in the event something goes wrong.
    Sent from the Starship Enterprise
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    /this
    It's because a legal issue to cover eventualities.
    Car-manufacturers give these warnings aswell for gas or oil etc.
  12. Bitwacker
    9 Nov 2009
    All quite confusing. What happens if you mix copper and nickel parts, does anti-corrosion work for both?
  13. Bitwacker
    9 Nov 2009
    I ended up bleeding my rid and am letting it dry while I rebuild my rig. Do I really have to buy EK specific coolant?
  14. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    You don't have to buy ek branded coolant, anything with a corrosion inhibitor should be fine, I'm using mayhems coolant and it seems to be fine.
  15. Bitwacker
    9 Nov 2009
    Do you need corrosion inhibitor and then a biocide?
  16. rollo
    rollo Modder
    16 May 2008
    considering how many people just use tap water and then add some anti corrosion stuff to it im surprised ek even bother to send the page out.
  17. Guest-23315
    Guest-23315 Guest
    This.
    Just use straight deionised water and jobs a good'un.
  18. Guest-16
    Guest-16 Guest
    This thrice.
    It's only a legal notice which means if you ignore it you can't sue them, but also clearly states that they won't qualify anything but their own fluid, which is not unexpected tbh given the range of liquids out there.
  19. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    This isn't possible, at least not completely. Hydrogen is just to damn energetic to be held in one place. It bounces from molecule to molecule. Hence at any given moment there are ions in le water, specifically H+ and OH-. I THINK that certain types of heavy water are a tad more stable.
    Correct me if I am wrong, I just couldn't stop myself despite risking PO'ing a mod :worried:
  20. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    deionized water is fine.
