News EKWB announces EK-Loop Connect control hub
Discussion in 'Article Discussion' started by bit-tech, 24 Feb 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. phuzz
    phuzz This is a title
    28 May 2004
    As someone who owns a lot of EK kit, but has been looking at Aquaeros recently (and wincing at the price), I'm interested....
    I couldn't give a flying monkey's about the LED controls though. I'd almost pay more for a version that was just about fan and pump control, with no lighting.
  3. The_Crapman
    5 Dec 2011
    Then you need a quadro.
  4. Impatience
    Impatience Minimodder
    6 Apr 2014
    I’ve seen recently that Barrow have a temperature sensor that can have a max temp set. If the fluid goes above this temp, the PC gets a power signal to shut down.. Would be good to know if any other brands have anything similar?
  5. phuzz
    28 May 2004
    Huh, I hadn't realised that they were more than just a four-way fan extender. I'll have a closer look, because it does look like it might be just what I'm after...
    Thanks!
  6. The_Crapman
    5 Dec 2011
    They have all the key functionality of an aquearo with the toss that no one uses cut off. I think the version of aquasuite you get is cut down, but then so is the controller. 4 fan channels, 4 temp sensors, flow sensor and an aquabus port to connect it to another device if you want. I mean, what more do you really need?
  7. phuzz
    28 May 2004
    Turns out that the Quadro does do everything I need (and it uses the full version of Aquasuite). Thanks for the recommendation!
Tags: Add Tags
