Hardware EKWB EK-XLC Predator 240 Review
Discussion in 'Article Discussion' started by Combatus, 25 Jan 2016.
  1. Combatus
    16 Feb 2009
  2. XXAOSICXX
    XXAOSICXX Minimodder
    20 Apr 2011
    Opening paragraph... "all manner of other water-cooling acessories" -> "accessories"
  3. Combatus
    16 Feb 2009
    Yeah yeah :) fixed, thanks!
  4. Baz
    Baz I work for Corsair
    13 Jan 2005
    Didn't this just get recalled?
  5. Guest-56605
    Guest-56605 Guest
    V1.0's As of January 13th 2016 yes - LINK
  6. Guest-16
    Guest-16 Guest
    Baz comes in like
  7. Combatus
    16 Feb 2009
    Revision 1.1 changes the mount and o-ring so it's easier to install and fixes the potential for it to leak as we mentioned at the end of the review. However, EK has told us performance is the same.
  8. Gadgety
    Gadgety What's a Dremel?
    23 Jan 2014
    Are AIO coolers maintenance free?
  9. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Am I correct in thinking that this is too think to fit inside a Corsair 250D m-ITX case?
Tags: Add Tags
