Electronics EL backlight query
Discussion in 'Modding' started by nosmo, 2 Jul 2004.
  1. nosmo
    nosmo What's a Dremel?
    5 Oct 2003
    Is it easy to remove the EL backlight from my LCD ?
    What can I use instead - LEDs ?
    I am fed up of looking for the correct spec inverter so have decided to find an alternate light source.
  2. LabRat1
    LabRat1 What's a Dremel?
    23 Jun 2004
    any inverter should work.. as long as it shocks the S :eyebrow: T out of you it should be ok
    **I have used different/wrong inverters in laptop screens and had no problem getting them to light
    I bet you could pick up a cold cathode case light and wire it up to the bulb in your screen
  3. nosmo
    5 Oct 2003
    My backlight requires an inverter running 100V AC @ 500HZ if I recall correctly.
    I daren't put anything different as
    A) I don't want to knacker the light and
    B) I have no idea what specs for my cold cathode inverter are - altohugh I could multimeter it I suppose.
  4. Skylined
    Skylined Minimodder
    3 May 2003
    I think you mean 110V 50Hz.
    I would use LEDs.
  5. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    No, he was correct in saying that it should be 100V 500Hz.
    I think farnell sell inverters, although they're slightly on the expensive side :sigh: . Part number 521-125
  6. nosmo
    5 Oct 2003
    I have given up trying to source one in the UK.
    They are far too expensive hence I am wanting to rip the s**t out of it and light it by some other means.
  7. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    just don't try to measure the inverters with a multimeter... it might damage the multimeter (to high voltage)...
    you COULD use LEDS, but the light won't be specially even if you don't use some sort of diffuser under the LCD, wich will be a bit difficult...
    I'd try to get an inverter instead...
  8. SteveyG
    23 Nov 2002
    Or design one yourself :dremel: Much cheaper and easier. :baby:
  9. nosmo
    5 Oct 2003
    Any help gratefully accepted :thumb:
  10. nosmo
    5 Oct 2003
    The specs call for 110V AC 500Hz
    Voltage is +- 20V
    Max is 1KHz
    If someone could help me design one that would run off computer voltages I would be very grateful.
  11. Jedi
    Jedi What's a Dremel?
    16 May 2004
    i actually tried this with a half decent multimeter that was good for 750v ac but there was serious sparkage so i though sod that !!
  12. nosmo
    5 Oct 2003
    I measured an inverter I have with my multimeter and it measured it fine.
    Its 2.3KHz though :sigh: so that one is no use to me :waah:
  13. JohnH
    JohnH What's a Dremel?
    14 Nov 2002
  14. nosmo
    5 Oct 2003
    Nice spot JohnH :thumb:
    Not seen them before and will certainly be mailing them.
    Thanks again.
  15. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Any UK modding shop that sells EL stuff with the included inverter. Any EL inverter will work. Theres a good range on those.
    Just stay away from CCFL inverters. Anyone saying that they will work has no clue.
    General specs for EL: 90-130VAC @ 100-400Hz
    General specs for CCFL: 300-1000VAC @ 30k-80kHz
    Big difference. Here in the USA we can power EL right of main lines. Its not as bright though, but a good test.
  16. nosmo
    5 Oct 2003
    Well the ones I have seen and the one I got outputs at way above my 1KHz limit.
