Modding EL cable and water
Discussion in 'Modding' started by Twernmilt, 1 Oct 2003.
  1. Twernmilt
    Twernmilt What's a Dremel?
    23 Sep 2003
    does anyone know if EL wire is waterproof?
  2. Darkangel
    Darkangel What's a Dremel?
    18 Aug 2003
    should be yeh as its in a plastic tube.. the ends arent tho
  3. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    hmm, el wire being run throught the tubing on a watercooling system? :rock: definitely take pics. :thumb:
  4. diskreet
    diskreet What's a Dremel?
    1 Oct 2003
    The tube iteslf is waterproof to me best of knowledge. I used it and spilled about 2/3 litre of iced tea on it, and it was fine. The only spot that you need to take extra care with will be the ends, specifically the one that connects to the inverter. the other end should be sealed the way it is.
  5. Zeke_D
    Zeke_D What's a Dremel?
    1 Oct 2003
    3mm and up
    fatter EL, 3mm and up is approved for outdoor and submerged environs. A few dealers specialize in water craft detailing with EL. Several companies are making life vests and fireman jackets lined with the stuff.
    Seal the end of the EL wire by heating the end till you get a nice melt, giving a rounded seal just like your pipets in chemistry class. This will water proof it.
    Don't know why the fine stuff, like angel hair, aint approved for water, might be due to the outdoor UV fade factor is higher on the fine EL stuff not that it aint water proof tho. Jus so you know, UV exposure will degrade the phosphor on EL, so if your doing UV lighting in your case, expect your EL to fade a bit after a year. Most variations in brightness from one EL vendor to the next has more to do with the inverter power source, higher or lower voltage, higher or lower frequency. 90V, 400Hz is common, but 120V, 2KHz is brighter but will fade the phosphor a bit quicker as well. The Aqua is the basic phosphor without any filter coating and can vary color from green to deep blue just by changing the frequency.
    If you want really bright EL wire, (comparatively), try finding some double core EL wire. Not that much more expense per foot.
  6. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    I had something really important to say... I have such a headache I can't think straight... I'll be back to edit this later... :blah:
  7. Twernmilt
    23 Sep 2003
    I have a bunch of LEDs and about 5ft of EL wire onthe way, i'm going to experiment and see what works better, i'll let you all know what happens with pics as soon as I finish my tests.
  8. ClearCaseMan
    ClearCaseMan Acrylic GOD
    13 Apr 2002
    the wire is but the ends arenot you will need to seal them up
  9. diskreet
    1 Oct 2003
    IF any of you need cheap el wire, like $10 per 3-5 feet, go to wal mart(if you can) and pick it up in the rice (auto neon) section. It wil be 12v, with an inverter, all you need to do is plug it into a molex connector, and you're done. works very well, as i have done this in the past
  10. Twernmilt
    23 Sep 2003
    The hard part is finding a place that carries WHITE el wire AND is cheap.
  11. ClearCaseMan
    13 Apr 2002
  12. Mombassaa
    Mombassaa What's a Dremel?
    27 Sep 2003
    Cheers for the link man.
  13. ClearCaseMan
    13 Apr 2002
    No prob I am here to serve :)
  14. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    post pics when you are done :D
  15. Twernmilt
    23 Sep 2003
    My gear wont be here until next friday :rolleyes: I should get everything done that night though and post on Sat.
  16. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Cooooool!
    Get me a soda :) :naughty:
