Electronics EL Wire Question
Discussion in 'Modding' started by DETN8R, 10 Sep 2003.
  1. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    How long would it take an EL Wire inverter to die or for the EL Wire itself to die.
    Ive been thinking of stringing some up but without a switch and leaving it constantly on.
  2. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Googled some specs through a retailer:
    Lifespan: 1000 to 25000 hours depending on AC frequency.
    Thats anywhere from 6 to 145 weeks. Ive seen sheets say tylical lifespan is 4000 hours. So Im guessing roughly 24 weeks typical.
  3. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    EL wire seems to be at the stage that early flourencent tubes are at. You have to replace it about once-a-year.
    My dad wanted to use EL wire to make a reflective light around his wrap-around deck, Until he found out how long it lasts.
    (His plans now are to use plain light strings.
  4. BasicBubbleHJK
    BasicBubbleHJK What's a Dremel?
    4 Feb 2003
    if you can afford it, side glow fibre optic cable could be used for the same thing
