Scratch Build – In Progress Electrocutous Orchid - final mod 2-25-14
Discussion in 'Project Logs' started by craig - toyoracer, 10 Sep 2013.
  1. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Hello BitTech modders, have started lets say a mid sized case build for my wife. This is to replace her dying laptop used mainly for Facebook, photos and web-browsing.
    The goal is have something semi portable around the house and good looking, Oh yeah must be Purple.
    Started a couple of months ago, needing to get something done to show you all and knowing there would be a summer break, did not want to start and then pause the log.
    So back at it now and happy to present you with
    Starting with the acrylic window, best to start with the most complex part first. Cut and bent it into shape.
    As you can see not real good, blistered the bends :duh:
    So made another and much better. I can live with that light blister defect
    Now onto the panels, aluminum this time round. Cut and bent the two rear panels.
    Made a narrow gauge bender to bend the opposite direction
    Test fitting :clap:
    Then onto the front panel.
    and with the top edge bent over
    So there we have the shape of the case. :naughty:
    Hope you all enjoyed the start of this little project. Back tomorrow:D
  2. Boorach
    Boorach Minimodder
    16 Feb 2013
    Some nice bending there! Going by the shape of the first couple of pieces this is going to be an interesting build. Look forward to seeing it progress.
  3. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    how hard is it to bend all the acrylic into the right shapes? im looking to make a protective cover for my keyboard
  4. craig - toyoracer
    1 Mar 2011
    Thank you, with 16 sides I sometimes question ...why :lol:
    well I will say you will need to practise first but not overly hard.
    The next step is to secure the panels to the acrylic. Using 1/4" stock cut out the basic shape.
    rough file them down
    a little sanding, tap some 6-32 threads and mounted. :)
    Now the other side
    made a fixture to hold while routeing a relief
    and start the file process
    layout and drill holes for venting slots
    file and sand
    Now for the base plate
    fan hole and mounting holes and relief for the rivets
    I glued a strip of black acrylic around the inside bottom edge of the window. These will hold the window legs in place and give a little contrast to the overall look. :)
    Mounted up.
    Now all completely mounted.
    Wow that was a big update. :hehe:
    Livio likes this.
  5. sethnmalice
    sethnmalice What's a Dremel?
    21 Jul 2007
    Very interesting build!!
  6. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    ohh, looks interesting, can't wait to see this progress.
  7. Cheapskate
    13 May 2007
    Delicious shape. I love the amount of work put into the DarthVader vent. too.
    You got Sethnmalice to chime in as soon as you posted the finished outer shape. -That should tell you how cool looking it is right there.:D
  8. Pierre3400
    Pierre3400 What's a Dremel?
    22 Aug 2013
    Holy hell the craftsman ship!
  9. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    You are good with metal my friend! Design looks very interesting
  10. craig - toyoracer
    1 Mar 2011
    Thank you very much, I'll say it took a couple of months to get the design right. :)
    Thanks, almost up to date.
    Thanks Cheaps I never seen the resemblance until it was done. :hehe:
    I had to check his work, as I do not know him. Nice builds Sethnmalice. :)
    Thanks Pierre.
    Thank you, metal just feels so good to play with. :)
    Now for the last part of the exterior I have done, still working on this.
    I will call these flower boxes :naughty:
    Cut the blank
    and bend, red line just shows inner clamp block
    and plant :hehe:
    small conduit next
    conduit ? remember this is an electric flower :D
    so in one goes, Power button, headphone and volume control
    making custom length USB's
    building back up the connectors
    result
    and the other planter filled
    So that takes care of the outside work done so far.
    Hope to see you all for the inside work. :blah:
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    This is looking awesome, good to see you making a new one Craig. :D
    The grill looks cross between Darth & a storm trooper, really nice grill, nice shape of case too. :clap:
  12. Attila
    Attila still thinking....
    22 Feb 2008
    Seriously interesting design Craig. And a nice first post of the project log, not a piece of hardware
    to be seen. Very refreshing! :thumb:
    The design and shaping of the grille is terrific and something I'll tuck away for future reference. :D
  13. craig - toyoracer
    1 Mar 2011
    Thank you Wayne, this was an unexpected build when the wife said can you make me a cute one. :clap:
    Always a pleasure to see you Mate, thank's. :)
    Happy to give back ;)
    Into the interior we go now. :
    Start with bending an internal frame with some rolled edges for a clean look. :)
    further bending, that looks good now
    motherboard tray cut out, no reason to follow the norm here :naughty:
    and a test fit of the hardware, aligns up nicely. :clap:
    so started with these mounting arms
    but realized after the HDD's need a different shaped arm, so remade them for this result. :)
    a flower is not square :D
    all together now
    I hope you enjoyed my play-time and may you all have a great week. :rock:
  14. Egami
    Egami Why is the dremel on fire?
    27 Aug 2013
    This is so bizarre... I'm all in!
  15. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Very interesting start to things! Will keep an eye on this :)
  16. craig - toyoracer
    1 Mar 2011
    Thanks man, nice to have you here. :)
    Glad to have your interest :D
    Busy with getting the house and yard ready for winter :brrr: but have managed a few more pieces.
    Cover plates for the flower boxes
    Time to sleeve those USB cables. Trimmed the connector and then use epoxy instead of shrink. Slower but I like the result.
    file off excess smooth
    and finish with some flat black
    The camera sees all, but from a short distance looks real nice.
    Maybe give a light sand and recoat.
    See you later. :D
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    Epoxy is a nicer look than heat shrink. :)
  18. Jeti
    Jeti What's a Dremel?
    9 Sep 2012
    Very nicely done. Subbed
  19. wes1007
    wes1007 What's a Dremel?
    8 Sep 2013
    That epoxy certainly looks neat! Subbed as well.
  20. Egami
    27 Aug 2013
    Finally a clean way to sleeve sata cables. :thumb:
