Scratch Build – In Progress Electrocutous Orchid - final mod 2-25-14
Discussion in 'Project Logs' started by craig - toyoracer, 10 Sep 2013.
  1. Guinevere
    Guinevere Mega Mom
    8 May 2010
    I'm loving the epoxy cables (Isn't everyone!). Have you heard of sugru? It's silicone based, flexible and real easy to work with. Although it's not so great if you want a nice clean geometric sanded finish like yours
    I'm certainly not saying you shouldn't be using epoxy... only that sugru is another tool for the box and I'm just spreading the gospel.
  2. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Go for it, it's really not difficult. :)
    Thank you and the Sugru does look like it has some good potential for some spots. :)
    I hope everyone had a great Christmas. :clap:
    Now this cable was a pain. As was the first DVI-D I was surprised to find a full metal jacket inside the rubber casing that you could drive a truck over it. :duh:
    So with some careful cutting :dremel:
    opened it up :clap:
    Then soldered up to HDMI, watch out for the pin-outs :wallbash: I had to do a couple of times :lol:
    Then using the trusty epoxy :D finished up the connectors.
    Think they turned out pretty well. :)
  3. craig - toyoracer
    1 Mar 2011
    I now have a nice black mobo. :)
    I think it turned out pretty well.
    See you soon. :)
  4. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I don't mean to be critical, because I totally want this build to succeed, but is painting a mobo a good idea? I'm worried about cooling and possibly shorting something out. I guess you're committed now, so let us know how it works!
  5. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Nice. I've seen a couple other modders paint their motherboards, so I'm sure it'll be fine, as long as the paint wasn't some caustic mix that'll eat any of the components.
    I like it, but I thoroughly convinced that it'd test my patience quite a bit taping off that many things lol
  6. craig - toyoracer
    1 Mar 2011
    Well it looks better. So hopefully my test of the paint was correct and all is well. :)
    Thanks Mosquito, but no tape was used, only a very small brush. :D
  7. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I'm not sure if that makes it better or worse! :lol:
  8. craig - toyoracer
    1 Mar 2011
  9. Cthippo
    7 Aug 2005
    1. Your wife is correct!
    2. Don't let the smoke out!
    3. Good luck, it's looking awesome!
  10. craig - toyoracer
    1 Mar 2011
    Thank you so much. :)
    I have very good news :clap: IT WORKS :clap:
    I now have a BIOS screen. :D
    So the final things can be taken care of now. :)
  11. ChromAnomaly
    ChromAnomaly What's a Dremel?
    7 Nov 2013
    Holy crap on the video cables. I definitely don't have that kind of patience (or the guts to cut through the metal jacket of my DVI cable), but they do look pretty amazing. As does the rest of the build.
  12. craig - toyoracer
    1 Mar 2011
    Thanks :D well it needed to be done, so cut away. :lol:
    I made some case feet from acrylic. Made a pin and one screw for the front ones. :)
    The painting has taken a while with a few variations along the way. :lol:
    Started with solid purple
    then some layering to get more of a flowerish look
    The final results will be revealed later :naughty:
  13. craig - toyoracer
    1 Mar 2011
    Gave a final brushing and clear coat to the bright parts. Also touched up those wrong holes. :)
    the back side of the mobo tray
    front
    top parts
    off to make the last two parts. :)
  14. Cthippo
    7 Aug 2005
    I still don't have a firm mental picture of what this will look like when finished. Guess I'll have to wait and see!
  15. Wonky
    Wonky What's a Dremel?
    7 Jan 2014
    Those cables :jawdrop:
    Sweet stuff. Subbed and can't wait for more!:thumb:
  16. craig - toyoracer
    1 Mar 2011
    I like surprises and I hope you do too. Should be a short wait now. :)
    Thanks Wonky glad you like them. :)
    Shortened and sleeved the antennas
  17. craig - toyoracer
    1 Mar 2011
    Since the case is meant to be portable, a handle is needed. Cut, drilled and filed a piece of 1/4" - 6mm aluminum into shape
    I was planning on laminating this between two pieces of black acrylic, but the wife liked it as is.
    So mounted the cable with epoxy and filled the holes
    now finished
    then a bracket was made to hold the handle when not needed
    Have a nice week and hope you enjoyed. :)
  18. Nexxo
    23 Oct 2001
    This is getting interesting... I'm getting associations with those streamlined chromed cars from the 50's. Cadillac Eldorado and Ford Edsel, anyone?
  19. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Yup agreed, especially the top parts, very nice!
    Did you have a chance to test the mobo after you painted it? It looks very cool painted and even though it will most likely work fine, it would suck if it somehow broke during painting.
  20. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    crazy job dude !
