Education Electronic Circuit Help
Discussion in 'General' started by longweight, 20 Feb 2012.
  1. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    When you get it finished stick a few pics up, be interesting to see :p
  2. longweight
    7 May 2011
    Will do! Also working on an Arduino build which should come to life on Wednesday!
  3. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    + -| water |- -
    water
    water
    + -| water |- -
    water
    water
    + -| water |- -
  4. longweight
    7 May 2011
    Ok so I have updated the circuit slightly :) I need to move on to the relay circuit for the LED's.
    If I am right the AND gate chip will output a maximum 12V at 3.6mA on each AND circuit. Chip link is here.
    Can I use this relay?
  5. Beasteh
    Beasteh What's a Dremel?
    18 Feb 2012
    Bear in mind that AND gate package has triple inputs. You'll need to connect a logic `1` (12V) to the unused input.
    Couldn't you use a transistor rather than a relay for driving the LEDs?
  6. DXR_13KE
    14 Sep 2005
    Discontinued product
  7. longweight
    7 May 2011
    Waaaa! Ok I think it is time to find a decent circuit that the AND gate can trigger....
  8. DXR_13KE
    14 Sep 2005
    Are you not using LEDs to signal the water levels?
  9. longweight
    7 May 2011
    Ja but the AND gate only outputs 12V 3.6mA or am I reading that wrong?
  10. DXR_13KE
    14 Sep 2005
    Going to this family datasheet:
    http://www.nxp.com/documents/other/HCT_USER_GUIDE.pdf
    Your device is a HE4000B family, on table 1 you see metal gate CMOS 4000 HE output drive.
    It looks like the standard output is 0.8mA @5V.
    edit: Consider putting the 2 sides of the sensor at the same level:
    edit2: You can replace the relays with cheap 2n2222 transistors or something simpler.
  11. longweight
    7 May 2011
    Ah yes! Having the sensors at the same level would make much more sense! So it can take 12V in and output 5V?
  12. DXR_13KE
    14 Sep 2005
    Do you want one led active at a time or can it have several LEDs lit?
  13. longweight
    7 May 2011
    I want to have them each light up in turn so when the tank is full there will be 3 LED's illuminated. I might have time to add a speaker with the last LED but I just need to get this bit sorted.
    Thanks again for all your help!
  14. DXR_13KE
    14 Sep 2005
    Does your project require you to use AND gates?
  15. longweight
    7 May 2011
    No but it cannot include a programmed chip such as a PIC chip.
  16. longweight
    7 May 2011
  17. DXR_13KE
    14 Sep 2005
    You could make it simpler by forgoing the AND gates and thinking of different connections between the opamps.
  18. longweight
    7 May 2011
    This is true but I quite like the AND gates, not sure why!
    So... the AND gate is going to output 0.8mA at 5V. So I can just use that to power something like this? http://uk.rs-online.com/web/p/visible-led/2285483/ Although I would think the current is actually far too low.
  19. DXR_13KE
    14 Sep 2005
    Use 3 simple transistors to drive the LEDs.
  20. longweight
    7 May 2011
    Will look into that tomorrow night, bed time now. Thanks again for all your help, wish I could do something for you!
