Modding Electronic tint HELP !
Discussion in 'Modding' started by MPovas, 23 Oct 2005.
  1. MPovas
    MPovas What's a Dremel?
    19 Dec 2003
    Hi...
    I was thinking that it would be cool when i wanted to tint my window and when i wan't - not. :rock:
    So do you know any way that i could do that? :wallbash:
    And it would also be great if i could regulate how much transperant it is...
  2. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Electronic Tinting material is very expensive and hard to obtain in small quantites. My university has some, but they are only to be used for school projects.
    From what I have played with so far, the amount of tinting is variable.
    I suggest that you instead utilize limo tint and regulate the lighting inside your case.
  3. mobius9
    mobius9 Minimodder
    4 May 2004
    from what I've read, it would cost over $300 to tint a regular window with the electronic tint. Getting some dark black and then making the amount of light in the case adjustable would do something similar.
  4. MPovas
    19 Dec 2003
    damn thats bad news :waah:
    The main idea is that i wan't to put a computer in my car...which would lead to 4 displays. 2 in the back for entertainment and two in front. Both clearly visible by the driver... For navigation, news, comlink, maps etc...
    So the tinting material is needed for the windows becaus of high crime the stuff visible in your car can get easily stolen and the law perhibits tinting the front side windows. And this would be a sollution cause i could drive with no tint while the car is parkinkg the tint is on....
