Scratch Build – In Progress Elite 330 "mod"
Discussion in 'Project Logs' started by M. Ehrlich, 13 Sep 2009.
  1. M. Ehrlich
    M. Ehrlich Avatar is my silhouette. :)
    13 Sep 2009
    Hello, this is my fist "mod". Original case is Coolermaster Elite 330.
    Modified parts:
    1) Cutted fan grills
    2) Removed 3.5" position for HDDs and Floppy drives
    3) Side (orange) panel a la Lian-Li PC 65b :)hehe:)
    Planned modifications:
    1) Paint interior to matt black
    2) Mod a front panel to this style
    3) Cut the window to side
    4) Paint exterior to gray Anthracite mettalic
    5) Flex visible cables
    Current status:
    (Sorry for my bad english.)
    Thank you for your comments.
  2. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    hi thats a great clean mod. if i was to get picky then i would say get an extension cable for your exhaust noctua fan and re-route that cable maybe at the top og the case or something, it doesnt look nice hanging in the middle of the case. Apart from that its great, really good design for some good airflow
  3. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Get some holes next to the psu to hide your cables. If you paint / powdercoat the case black it will definately be awesome!
  4. M. Ehrlich
    13 Sep 2009
    Thanks for replies!
    Noctua cable update
    //Computer Specification:
    MB: Gigabyte GA-MA770-DS3 rev.1.0
    CPU: AMD Athlon 64 X2 5000+ Black Edition, 200x16 = 3.2Ghz, 1.38V with Zerotherm Nirvana
    RAM: 2x1GB A-Data Vitesta 800Mhz CL4, 2.0V
    GPU: BFG GF9600GT 512MB PCI-E with Accelero S1 and Nexus @ 500 rpm
    HDD: Samsung 160GB SATA II
    DVD/RW Drive Samsung SH-S223F SATA
    PSU: Fortron 500W with Noctua NF-P12 @ 1.000 rpm
  5. flame696
    15 May 2009
    That's better, better airflow and looks better
  6. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Looks good, gonna look a lot better when you spray the insides black.
  7. M. Ehrlich
    13 Sep 2009
    Painting in progress
  8. ry@n
    ry@n Minimodder
    31 Aug 2005
    Looks really good! as above, it would look really good with a black chassis.
