Electronics EluminX Keyboard Issues
Discussion in 'Modding' started by Langer, 30 Oct 2004.
  1. Langer
    Langer Jesse Lang
    24 Jan 2004
    I've had an EluminX Keyboard for about 6months now and recently the EL-sheet stopped "illuminating" and the keyboard began emitting a horrible screeching noise. I took the keyboard apart and unplugged the EL sheet from, what I assume is its, power source. Any of you electronic experts have any advice?
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    bump ne one?
  3. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    methinks the inverter is shot. a lot of early generation EL inverters do that. You have four options here: either replace the inverter, pad it with noise sucking foam, try to return it, or buy another, change inverters and return the new one with your shat inverter.
  4. Langer
    Langer Jesse Lang
    24 Jan 2004
    I like that last one...thanks for the advice
    /me emails local PC shop
  5. Tulatin
    16 Oct 2003
    either that or just swap them and send it back lol.
