Other Embarrasing question to ask!!
Discussion in 'Hardware' started by chrispy61, 27 Dec 2010.
  1. chrispy61
    chrispy61 What's a Dremel?
    29 Jan 2010
    Whats the diffrence between 3.5" and 5.25" drive bay? Is it the depth? Reason im asking is because i wanna add a card reader to my computer and its listed as 3.5". So will it sit flush in the front of my computer bay like the disk drive does?
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Width really, but 3.5s generally aren't as deep.
    5.25" bays are for CD drives, 3.5" for floppy if that makes sense?
  3. cdb
    cdb No comment
    25 Apr 2009
    It might do. I have a card reader in my new and old PCs. In the new one it sits flush, in the old one is sits about 1cm proud.
    The 5.25 bays are wider at least, for optical drives etc. I'm not sure about depth though.
  4. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    3.5" are for floppy drives, hard drives, and 99% of card readers
    5.25" are for (most) fan controllers and cd/dvd drives.
    Its just the width of the bay.
  5. chrispy61
    29 Jan 2010
    so how would a 3.5" card reader look in my case? Would it have a big gap around it? Confused.com :confused:
  6. chrispy61
    29 Jan 2010
  7. ElThomsono
    18 Mar 2005
    If you look at the above picture it has 4 5.25" bays (one with a CD drive) and 2 3.5" bays (one with a floppy drive)
    If you have a spare 3.5" bay you can put the card reader in it, otherwise you'll have to get a converter to put it in one of the 5.25" bays.
    Or live with a massive gap and not actually have it fit in the slightest way ;)
  8. chrispy61
    29 Jan 2010
    Thanks man thats what im gunna do. :thumb:
