Hardware Emprex NSD-100 P2P Download Engine
Discussion in 'Article Discussion' started by Tim S, 29 Apr 2008.
  1. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    What about HD's that are already formated and have data on them? plug n play? Or do you have to format it?
    Cool little device, may have to grab one eventually.
  2. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    Got one ordered, should be with me in a few days. My wife is going to love setting this thing up.
    It wouldn't surprise me if this is one of those things that takes off on the modding side depending on what people can get to run on it.
  3. Lemmingzappa
    Lemmingzappa What's a Dremel?
    8 Nov 2004
    Just recieved mine, seems great so far, but I dont have my 16GB flash drive yet so I cant use it properly !
    EDIT: WARNING:
    The storage device you connect to this product must be atleast 10GB in size !
  4. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    That seems a rather random limit. :confused:
  5. Lemmingzappa
    8 Nov 2004
    Yeah it's rather strange.
  6. mattthegamer463
    26 Nov 2004
    I see that it doesn't run NTFS, only FAT32 and "linux" format. That kind of sucks. I really like the concept of an all-in-one device for those "little tasks" that keep your PC on all day, but the limitations just make me want to turn off my fans and underclock.
  7. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Its a linux box why would it run NTFS? ext3 is at least an equal to NTFS and since its a network device and not a USB device why would you care what the underlying hard drive format is?
  8. Lemmingzappa
    8 Nov 2004
    Using it now with my new OCZ flashdrive, I'm loving it !
  9. E-Jungle
    E-Jungle What's a Dremel?
    23 Jan 2007
    any reports on LAN transfer speeds from the current owners?
  10. Lemmingzappa
    8 Nov 2004
    slower than I thought it would be LAN wise, although I dont know if that's because i'm running it through two homeplugs (through the house mains) which are both on extension leads, so they're not getting their top speeds. I'm also running it off a flash drive rather than a hard drive, which I imagine will make it even slower.
    Probably better to ask someone who's running their machine directly to the router and using a proper drive.
  11. DannyDirect
    DannyDirect What's a Dremel?
    23 Apr 2008
    Hmm, useless? haha
  12. mattthegamer463
    26 Nov 2004
    Cause I don't intend on keeping my hard drive permanently affixed to it, and since NTFS is the standard for drives these days on Windows, NTFS would almost be considered a requirement for the majority of people to make proper use of the device.
  13. goobt
    goobt What's a Dremel?
    5 Jun 2008
    What OS does the NSD-100 use?
    ex:ucosii, ecos, uClinux, ...
  14. slewis1972
    slewis1972 What's a Dremel?
    30 Jul 2008
    Any ideas if you can use it as a webserver also if your website is stored on the usb hdd?
    Scott
  15. scuzzphut
    scuzzphut perfectly normal
    5 Aug 2008
    this device looks like the perfect way to share a printer and an HDD over the home LAN - It seems to be the cheapest solution to that problem ,even without the BT client.
    Anyone know if it handles multi-funtion printers - ie can you scan over the LAN from a printer/fax/scanner ?
  16. Guest-16
    Guest-16 Guest
    Slewis, Scuzz - sorry I've no idea, the product has since been returned after we reviewed it.
  17. nobrob
    nobrob What's a Dremel?
    17 Feb 2009
    Several major problems with this device:
    - There is a blog on the net that suggests a firmware upgrade, but I struggled to find the download!
    - The same blog suggests you can put any Linux distro on the machine, but not as firmware, instead it would be a usermode linux type thing (unsure).
    - 10GB minimum (wtf) as per previous comments is true
    - Only natively formatted disks.
    - Mine was unreliable so I returned it. This may have been my specific box, but I've read others have the exact problem: it will stream data to an HTPC for a while and then cut out.
    Bought myself a second hand NSLU2 and I'm loving it!
    All the best.
  18. gypsypunk
    gypsypunk What's a Dremel?
    28 Jun 2009
    hi can enyone help got one of these and setting up is a problem ie..
    i loose internet connection when setting up
    connection through wan miniport (pppoe)
    error 815 broadband network connectorcould not be established on your computer
    because your remote server is not responding
    i have managed to set things up but get no connection
    heeeelp
  19. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    I don't see why you'd need to take your firewall down for the bt client.. just forward the port you want to use
    and the split usb cables aren't really needed with usb 2.0.. also you could start torrents if you left a rig on (but then that defeats the whole point of buying this for me) with remote desktop- this is a cool little device for peeps who can't setup a network.. not being able to access the torrents remotely out the lan is kinda strange- maybe they figure it's saving you from yourself as you also won't be running any blacklists (which is not a good idea anyhow- especially nowdays)
  20. gypsypunk
    28 Jun 2009
    hi can anyone help with advice on pppoe can we get it in the uk .... if so is it with a wireless router
    my guess is i can only use this with pppoe
    as i get the error 815 pppoe .... and loose Internet connection
    i have tried on the emprex forum but pointless ... the worst ever support i have come across
    any advice would be appreciated
Tags: Add Tags
