Electronics empty RGB holes in my daughter board pcb
Discussion in 'Modding' started by thermoking, 11 Aug 2004.
  1. thermoking
    thermoking What's a Dremel?
    11 Aug 2004
    im modding a third party ps one lcd monitor and noticed this on its daughter board[​IMG] is it posible to use these to conect to a vga monitor
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Mabye, but you need V-sync and H-sync
  3. thermoking
    11 Aug 2004
    which isnt posibble is it?
    By doing a continuitity test on the daughter board for the monitor ive found only 2 conections from the Ps ONe A/V Plug which go to the lcd controler board
  4. thermoking
    11 Aug 2004
    after an on/off switch and a Game/A/v select switch there are only 6 wires going to the controller board plus a Ground wire one off the 6 goes to the so called speakers But i dont want sound just a Vga output
  5. thermoking
    11 Aug 2004
    Updated Pics
