News Enermax announces self-cleaning DF Pressure fans
Discussion in 'Article Discussion' started by Gareth Halfacree, 29 Apr 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. Vault-Tec
    30 Aug 2015
    Didn't MSI do that on their GPUs like aaaages ago?
  3. Gareth Halfacree
    4 Dec 2007
    That's a software thing, though: what Enermax has patented is having the fan do it by itself (i.e. you connect one of these up to a power supply, absolutely no intelligence in the loop, and it'll reverse for ten seconds then spin normally.)
  4. Vault-Tec
    30 Aug 2015
    Oh I see. So the same thing only different? :D
    I like the idea of it, however I don't like the idea of my Alienware huffing dust in my face every time I swtich it on (it faces upward lol).
  5. Gareth Halfacree
    4 Dec 2007
    Like 90% of the patents out there, aye!
    Yeah, I'd want to think carefully about where I was actually using these.
  6. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    So it goes into reverse for 10 seconds to clear the dust. Then spins up and sucks the dust back over the fan :eyebrow:
  7. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    Yeah, that's exactly what I thought...
  8. Vault-Tec
    30 Aug 2015
    I've seen it in action and it doesn't quite work like that. It tends to throw off fluff balls which are heavy enough to drop to the floor (or the floor of your case) pretty quickly so that they don't get sucked back in.
    With fan filters though they could actually end up clogging them far sooner.
  9. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Other way around: if you have fan filters this will unclog them by reversing the flow. This is exactly what industrial vacuum extraction systems (and site vacuums) do to prevent their filters from becoming clogged by particulates. Many will even have a fancy multi-fan or multi-duct system to allow them to continue 'sucking' through one filter while the other is reversed to clear it. That's why if you're using one for a long period of time you will occasionally hear it 'clack' as it cleans the filters.
  10. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Yet more fan gimmicks to generate sales. I bet the fans will be expensive because of this "amazing" feature, and of course being Enermax. Couldn't they have simply shown a video of the technology in action instead of copping out with a run-of-the-mill 3D animation and epic soundtrack?
    Plus, anybody with a basic understanding of aerodynamics will know that a PC fan spinning in the wrong direction will generate barely any airflow at all because of the curvature of the impeller blades - they're designed to work in ONE direction, not two. Ten seconds of counter rotation with very little airflow won't achieve much if anything at all, but hey, it'll generate sales!
  11. Tynecider
    Tynecider Since ZX81
    23 Jun 2009
  12. edzieba
    14 Jan 2009
    Only if you believe airfoils operate on magic rather than fluid flow. Running in reverse will be slightly less efficient and slightly noisier, but will still generate plenty of airflow. Same reason aircraft can fly inverted with minimal issue: lift is generated by shoving an inclined plane through a medium. All the rest of the wing chord shaping is to do with making that inclined plane more efficient. Computer case fans spin FAR to slowly for chord shape to be making a significant difference in generated airflow.
  13. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Well that's it - I believe that fans are all about magic, especially the ones with the most vibrant colours and brightest LEDs. :rock:
    What you're saying is true, but it's still just a silly gimmick. The best way to get dust out of your system is -- surprise, surprise -- to clean it manually.
  14. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    so it goes full blast for 10 whole second, and there's nothing u can do stop it??
    there goes putting it in a silent build.
