Hardware Enermax ETS-T40-TA review
Discussion in 'Article Discussion' started by brumgrunt, 6 Dec 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    good to see lots of hardware reviews, but I'd prefer a 12 page cooler review roundup at end of week.
    Do i buy a cooler now, or do i wait till next week incase an ULTIMATE EXTREME cooler is still to come...
  3. GeorgeK
    18 Sep 2010
    ^ That'd be the H100i...
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    'one thing struck us as a little out of the ordinary, namely the baseplate. It uses what Enermax terms Heat Pipe Direct Touch, which is exactly as it sounds. Rather than a traditional smooth baseplate, the four heat pipes themselves are flattened out and make direct contact with the CPU. '
    Erm... Don't loads of coolers use this design...
  5. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Yeah, that is a little odd to draw attention to that 'feature' as though it was something special or new, which is actually rather common among many heat sink bases...
  6. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Yeah, the direct-touch design is very common...and very commonly not very well implemented, as Enermax has done. The idea of the design is good, but you can't half-ass it - there shouldn't be massive gaps between the pipes and the base.
    Also, no AMD testing at all? I am disappoint.
Tags: Add Tags
