Hardware Enermax Infiniti 650W
Discussion in 'Article Discussion' started by Tim S, 9 Dec 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Great review as always :thumb:
    I still don't need more than 400W (probably closer to 200W), but then I am using 3 year old hardware.
  3. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    I agree with that review - a product should be able to meet its listed specifications, lest the producing company throw its reputation into the flames to save a few pence per unit. False advertising sucks :(
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    Even tho PSU's are what feeds the beast inside, I continue to think that they are overpriced.
  5. Guest-16
    Guest-16 Guest
    You can make a **** PSU real easy - just look at all the "1000W for £50" ones out there, but to make a decent, stable one with high efficiency is actually quite difficult. You get what you pay for.
  6. Krikkit
    21 Jan 2003
    I can see the man's point - they are quite an expensive piece of a build, and not really that exciting, so it feels like a waste a lot of the time to spend a big chunk of your budget on a PSU.
    However, it's madness to skimp on the heart of a rig, and there're so many PSU's out there today which are of such high-quality compared to a few years ago that it can be very difficult to choose...
  7. Guest-16
    Guest-16 Guest
    You don't have to review them :(
  8. Krikkit
    21 Jan 2003
    :hehe: The burdens of journalism! ...Or being Tim's victim... :worried:
  9. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Yeah when I first started OCing afew years ago when I joined this site I didnt understand how a good PSU was needed, it was only a few years later when taking my brothers PC apart to clean it that I noticed his generic PSU had a higher power rating (or whatever it is 350 mine was only 300). Anyway I stole it and swapped them around, managed to get afew more mhz out of my Barton-M with it too, thats when I realised it was an important component, now I would only buy a decent PSU :)
    Edit: Ow I am using a corsair PSU now not the generic one lol
  10. Guest-16
    Guest-16 Guest
    Help!
    :worried:
  11. quack
    quack Minimodder
    6 Mar 2002
    Quite disappointing results. I bought the 720W version on the value of your review, hopefully mine is doing what it says on the tin.
  12. Guest-16
    Guest-16 Guest
    Well I've changed testing techniques since then having learnt far more about it, and now I test 3.3V and 5V separately to 12V. Joe uses the 720W in his machine all day everyday since testing it originally and it's not let us down once.
    99% of people should be fine with it - you rarely stress the 3.3 and 5 in a modern system.
  13. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Have you folks tried running them on 110V?
    You may find they come closer to spec.
    Phil
  14. Guest-16
    Guest-16 Guest
    Kinda hard in the UK when we're all 230V ;)
    Even if we could, we're a British site and our British readers can't exactly switch to 110V :)
  15. Phil Rhodes
    27 Jul 2006
    I'm in the UK too, but given that most of them are... what are they, buck converters, it might explain the difference. You'd just need a big transformer.
  16. Phil Rhodes
    27 Jul 2006
    Pardon me, I think this one here is a half-bridge, but the point stands.
  17. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    230v norm gives better power then 110v unstable lines
    got to replace my 2 year old Enermax liberty max due to water been pored into it lol
  18. Drexial
    Drexial Minimodder
    28 Jul 2005
    thats not how you liquid cool a PSU. It prefers Ginger ale.
    Anyway. I used to have an Ultra-X PSU and i was running a pretty hefty air cooling system on it and decided to go liquid as well. got that ll hooked up and it seemed to run without a problem. Then i decided to add one more fan for an external HD, I got instability galore with just the addition of a 80mm fan. decided to leave off the 80mm and swap out the PSU for a new one. Now im running an OCZ . Have to say it runs amazingly. Was able to over clock a lot more stable . It was only a difference of 20 watts that i added, but i doubted that i should have even been using all of the 480 that i had before i went to the 500 watt.
Tags: Add Tags
