PSU Enermax Liberty 400W PSU Vs E8500 + GTX 480! PhysX Challenge!
Discussion in 'Hardware' started by Blogins, 8 Apr 2012.
  1. YES, it will work flawlessly!
    30 vote(s)
    57.7%
  2. NO, it will never work!
    22 vote(s)
    42.3%
  1. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Having just won a bargaintastic GTX 480 with EK block on ebay I'm curious if my little Enermax Liberty 400W PSU can hold its own against the onslaught of an E8500 and GTX 480 combined on a 680i motherboard. Not the most power efficient combination but this is an Enermax PSU. Should it fail I do have an Enermax Galaxy 850W PSU on standby! Although for this test I may need to turn off the Delta fans! :D
    Care to place your bets?
  2. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    You'll probably be ok. Enermax is a very good make, so it should be okay.
  3. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    this is like the old tv show you bet. but minus the peado. lol i'll go for yes!
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    Ooph, I bet it'll fail on Furmark.
  5. Harlequin
    Harlequin Well-Known Member
    4 Jun 2004
    oooooh how cheap was cheap for the 480?
  6. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    I'll have to throw my money in with the 480, that thing is a power hungry monster, and with those fans on there's no way it will succeed. But turning off the fans wouldn't be fun, now would it? :thumb:
    Why not just install the 850w in the first place?
  7. Blogins
    3 Aug 2010
    Where's the fun in that?
    The GTX 480 with EK water block cost a cool £149 which I think is pretty damned good! :D
  8. Harlequin
    4 Jun 2004
    lol make a video :D
  9. law99
    law99 Custom User Title
    24 Sep 2009
    **** the bed that is good.
  10. j4mi3
    j4mi3 New Member
    28 Jun 2011
    I reckon you should.be ok.
    With a worse brand then probs not
  11. Blogins
    3 Aug 2010
    I know, couldn't believe my luck. Must be a quiet Sunday on ebay! :thumb:
    Also being delivered in a GTX 680 box which is kinda nice since that'll probably be my next air cooled PC upgrade!
    Anyway, back on topic. Here's some power draw results for my 680i and E8500 from the mains.
    This is with a low power passive GPU installed and sound card along with a D5 pump on full whack.
  12. Mac_Trekkie
    10 Sep 2011
    Well what are you waiting for? Go melt that Enermax!
  13. Blogins
    3 Aug 2010
    Well, the GTX 480 needs to be delivered and I need to install a second 240 RAD in my loop!
    Also I'm fixing the second 240 RAD with some heavy duty silicone water proofing since the thread is damaged. :D
  14. The_Crapman
    5 Dec 2011
    Queue A-Team-esque modding montage....:dremel:
  15. erratum1
    erratum1 New Member
    30 Apr 2009
    Take the card up to a 100% and leave it there for a while, might be ok......but probably not.
    What would be funny is if the Psu went bang and took all your kit with it.
  16. Mac_Trekkie
    10 Sep 2011
    Shhhh, don't scare him, wait until it happens then laugh at him!
  17. leslie
    leslie Just me!
    19 May 2009
    You do realize that running it underpowered will not only damage the PSU but also the other components right? You may as well give it a good voltage spike at the same time, it will do just as much damage.
    With the 400, it will boot and it will probably run, but under a a good hard test, you will be dangerously close to under-powering everything (causing damage) and burning up the psu.
  18. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    You do also realize that something like that is only likely if your buying a crappy PSU from Maplin or something like that, Enermax PSU's are to my mind the best engineered PSU's you can buy, its more than likely that if that PSU can't handle the load it will just simply switch the system off rather than taking any components with it.
    Although its considerably newer, take the Maxrevo 1350 review from TTL as an example.
  19. Blogins
    3 Aug 2010
    Well, it is only my fun experimental PC! So I'll still be Battlefield 3 capable! :D
    Also I've never had an Enermax PSU go boom, but my previous AX850 did go pop at 500W load!
  20. rollo
    rollo Well-Known Member
    16 May 2008
    Anandtech pushed a 1250 watt to 1700 watts so I'd say you have a decent shot at this working gl
