News Enermax unveils ELC120, ELC240 liquid coolers
Discussion in 'Article Discussion' started by Gareth Halfacree, 3 Oct 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Wonder what the performance is like on these and if they can compete with the Corsair systems???
  3. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Another rebadged Astek closed loop :).
  4. whatsthatnoise
    whatsthatnoise What's a Dremel?
    21 Mar 2012
    There's a review with a pre-production sample of it over here.
    Seems like it it's pretty comparable to an H100. Not quite clear which fan settings they used, though.
  5. [EOCF] Tim
    [EOCF] Tim What's a Dremel?
    26 Oct 2005
    It's actually made by Asia Vital Components.
    I was hoping this was going to be at least better then the H100. Not sure what fan settings were used, but seems that the H100 cools better with lower decibels. I was really hoping those silent fans would be great.
    On a side note, I wish they would test the kits with the exact same fan, at least in one test of the review. That would really highlight how well the rad, block and pump work. Now you are just guessing.
    It will be interesting to see the difference between the dual 120mm offering and Corsair H60/H80.
    Pretty please Bit-tech, review these as well.
  6. mediapcAddict
    mediapcAddict What's a Dremel?
    8 Sep 2010
    I guess you could say the water cooling market is hotting up :)
  7. Tynecider
    Tynecider Since ZX81
    23 Jun 2009
    +1
    If not, Same performance me bets
  8. Guest-16
    Guest-16 Guest
    But Tim already said it wasn't 2 posts above :confused:
    Worth finding out at least. ;)
