Modding Engraving 101
Discussion in 'Article Discussion' started by Tim S, 10 Jul 2007.
  1. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Is it possible to engrave on powdercoating? My next case will be powdercoated but I want to pick up my dremel again.
  2. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    The best thing in this article? It's because it drags Bit-tech back to its roots!
    Before this site is what it looks like now, it WAS a modders TOP reference site. Actually it was that what catch my attention in the first place.
    There where a TON of wonderfull nice articles like that.
    I really hope that Bit-Tech includes more articles like that one!
    Cheers!
  3. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    I agree with Yemerich ! :thumb:
  4. DSquareD
    DSquareD What's a Dremel?
    24 Nov 2005
    maybe this has been asked but im a huge huge huge fan of engraving and im farely good at it...havnt had much practice as of late seeing as how imm out of a dremel or bits...my old fake dremel blew and my bits got lost...so im looking 4 a new one when i can afford them (theyre damn expensive here in south africa)...k so anyways b4 i steer too much off topic...my question (aimed at Wolverine) is about the engravings done on the metal cases. do you spray them with a coat of clearcoat after you're done engraving them?
  5. Sandwich
    Sandwich What's a Dremel?
    21 Jun 2007
    can you only engrave anodized metal. or can you engrave painted metals as well. what are the differences?
  6. [WP@]WOLVERINE
    [WP@]WOLVERINE What's a Dremel?
    18 Oct 2003
    Well you can clearcoat the engravings if you are worried about rust but personally ive never done that and i have never had any problems with rust.
    You can engrave any surface it doesnt matter at all if its anodized or painted you still do it in exactly the same way.
  7. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    wow sweet etching, looks really good
  8. sinkhead
    sinkhead Pleh
    4 Aug 2007
    Excellent guide! I might even give it a go...
  9. Bl4ckM0onk3y
    Bl4ckM0onk3y in luv 2.0
    5 Aug 2007
    i'm in the process of engraving my Mystique 632 right now , using different method for transferring the template onto the case panels. Taking pictures as i go so hopefully it will be nice or a complete disaster ;D
    P.S. The Pentagrams used in this article are the "real bad" pentagrams , these are described as the symbols for Satanists , the "good" Pentagram is inverted and it's a symbol of protection.
  10. DSquareD
    24 Nov 2005
    i have a quick question.
    the detailing done in dots or lines...how is that done?
    i tried doing dots in a plexi engraving of my own and i had no idea what i was doing...do u simply make lots of dots that are touching?
  11. [WP@]WOLVERINE
    18 Oct 2003
    To give a simple answer to that....YES :)
  12. jamie_2k7
    jamie_2k7 What's a Dremel?
    19 Nov 2007
    wow amazing .... id love to be able to do that ... im thinking of giving it ago :) just wondering where would i get them leds from ? and how would i power them ... im wanting to make a sign for my wall with that effect :) think it would look cool any help would be greatly appreciated
  13. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    How do.
    Just joined the forums after reading a spate of articles on modding. I read through the engraving article and enjoyed it so much that I bought a Dremel 400 XPS kit the following morning. Bit of an impulse, but I thought, why the hell not! Thing came with the flexi-shaft, so hopefully it is as useful as is stated in the article.
    I am thinking of engraving the righ-hand side of my Gigabyte 3D aurora 570 case with an image and community tags to get me started. I am hoping it is simple enough.
    If anyone would have any recommendations and/or tips, they would be appreciated.
    Like I said, extremely good article, got the brain going into overdrive again. :clap:
  14. The_Beast
    21 Apr 2007
    I got to use a CNC mill/engraver today
    it was so so easy
    1. Draw an engraving in AutoCad
    2. Convert to MasterCAM file
    3. Make a toolpath and enter tool type
    4. Save the CNC code
    5. Open Techno code and start engraving
  15. ozz
    ozz Nerd? Yep sure am & proud of it.
    2 Sep 2008
    sorry this has nothing to do with beliefs or whatever....but...
    After engraving the case metal is there anything needed to seal or protect the newly exposed metal? ie to stop from rusting or anything?
  16. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    Old article but I don't think it was mentioned and might still be useful:
    I think you can do larger area patterns on alu/steel by using a common wire brush bit, or by not using a dremel but a punch and just hammer a lot of dots, that's a bit time intensive though, but it's how they used to do some classical designs in ancient times
Tags: Add Tags
