How do you enable the use of the svid and copsite vid on a Epia board? any programs? Windows dosnt see my tv when its hooked up. any suggestions?
Check your motherboard manual. iirc there is a jumper or set of jumpers to switch between some outputs. There's also BIOS settings involved. I think they sometimes label things strangely in the BIOS so you are safest hooking up an old CRT to the VGA and making sure everything works from there before changing the output. Remember to first set the output to something like CRT + TV so that you can confirm that everything works before changing to just TV output. Hope that helps.
