Scratch Build – In Progress Epic PC X Series 20.10.2010 Its over, finished, complete. Come one come all :)
Discussion in 'Project Logs' started by Djayness, 1 Feb 2010.
  1. Voluntary_Pariah
    Voluntary_Pariah a Real Man™
    23 Jan 2009
    I have been reading the log for a while and have been constantly impressed.
    You attention to detail has given me a number of ideas that I plan to incorporate into a Mod at some point (hopefully very soon)
  2. dream caster
    dream caster just lurking from out there
    1 Jan 2002
    :waah:
    I do not like SATA sleeved.
    if you want to change sata cable color, better paint it.
  3. GuyInTulsa
    GuyInTulsa Dremel Molester
    6 Jun 2009
    This is great CNC work!
    Really wish I had one.
  4. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    There is more greatness in this build than just cnc.
  5. voigts
    voigts What's a Dremel?
    26 Apr 2006
    +1
    This build couldn't be done the way it is without the CNC, but the CNC only does what it is programmed to do. There is a lot of thought and creativity going into this build.
  6. Djayness
    Djayness phwupupupup
    7 May 2008
    Yeah its oddly assumed that the CNC does all the work but really one has to design, toolpath, operate, assemble and hope that the final product lives up to its billing!
    Update time!
    Im a net addict and having this much downtime on the computer is really killing me, I traveled to my brothers place to surf the net, sad sad life.
    Much has happened since I have been gone, I got enough material here for a few updates but I guess I'll just splurge it all at once and hopefully you guys can keep this thread alive whilst I continue the install.
    I showered my PC, gave it a good clean!
    I have a history of having a shower with my pc :p , this is me showering with my old build.
    I cleaned it down with a bit of isopropyl and a lint free cloth....my glasses cloth actually. After meticulously getting inside the edges and side panels, I decided to do a test fit. Nice and shiny :)
    I removed all the stock cooling and started getting my bitspower on. That "bridge" shot between the mosfet and NB actually has two compression fittings and three 90 degree turn bits. thats over $60.00 worth of bits on that small part alone. Its actually XSPC's fault for the extra 90 degree bit as they made a rediculously large mounting plate for the Delta CPU block (its also my fault for buying it all those years ago but we don't talk about that anymore...).
    Mounted the bottom radiator and managed to squish the fans, filters, rad plate and radiator onto a single huge m4 bolt.
    Creating the rad plates took alot of time. Multiple passes were needed to make sure the material didnt vibrate whilst doing the grills.
    On second thoughts, I should have made the computer like this, taller rather than longer. I'm not having height issues but I know alot of people would rather a front mounted triple radiator setup.
    Anyhow, I expect to be offline for a while, at least until the leak testing is done. I am going to plug my spare 450w corsair unit into the computer as I stuffed up the PSU wiring, the heatshrink is too close to the end of the wire so it wont fit back into the ATX connector. Noob mistake I know but seriously, never sleeved before so I am litterally ripping my hair out over this. I have to trim and re heatshrink every single wire and to be honest, not sure if I have enough heatshrink.
    The main part now is getting the water running and putting my comp back online. I really want to see some NB and SB temperatures! The maximus SE "fusion" block was absymal really, it wasnt even copper so I'm pretty sure I will see immediate improvements.
    My list of stuff to do isn't extensive, its just time consuming.
    PSU rewiring
    CPU 8 pin sleeving
    Lighting
    Cable management
    Build a lightbox ** - I really want to build my own lightbox, one that is big enough for the case. There seems to be quite a few guides on how to do it and im actually quite confused as to which one I will pursue. Any tips would be great!
    Lamptrons Goodies have arrived by the way. I will do a post about it once I get my computer online!!!!
  7. Jipa
    5 Feb 2004
    Good work there, looks sharp!
    Also lol at the shower scene.. Been there, done that! With a case, pile of scrap acryl, and even my bike :p
  8. Djayness
    7 May 2008
    Cheers!
    Also MOTM just went up and I'm a nominee! If you think I'm worth a vote then head over to the voting page :)
    Which can be found here!
    ps. I got the old oil pc running again just so I could be on the net, I need some serious help.
  9. mrdbristol
    mrdbristol Voided my warranty years ago
    8 Aug 2008
    Got my vote :thumb:
    Some great work going on in this build :D
  10. o1wish
    o1wish What's a Dremel?
    5 Mar 2010
    i could imagine how tiring the sleeving could have been! kudos to your fiancee for agreeing to the work! great designs also. keep up the great work! i'm totally crushing on your build :p
  11. paultan
    paultan R E V E N T O N
    22 Jan 2010
    priceless!
  12. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    Nice update!
    Heh, I pressure washed my last acrylic build, works wonders at getting everything off :p
  13. talladega
    talladega I'm Squidward
    18 Aug 2007
    i'd recommend getting some Novus polish. It makes the acrylic not attract dust so easily.
    your whole case looks really excellent so far!!
  14. voigts
    26 Apr 2006
    You got my vote. Keep it coming.
  15. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    +1 :clap:
  16. Djayness
    7 May 2008
    Thanks guys!
    I have taken a rest to give you guys a teaser!
  17. o1wish
    5 Mar 2010
    Clean tubing! Are you keeping it clear or are you putting dye in there?
  18. Djayness
    7 May 2008
    Orange dye bombs and UV Gold, Should be some pics up by tomorrow!
  19. The boy 4rm oz
    10 Apr 2008
    I have just read through the entire thread Daniel and I must say that this mod has awesomeness in epic proportions, like how I through that pun in there lol. Your skills with your mill is remarkable as is your design skills, a very very well designed and executed build so far. I can't wait to see how everything turns out.
    One thing, would you be interested in making those water blocks for sale? I am looking into blocks for my new build and would love to keep the cash within Australia.
    Once again, awesome work so far.
  20. Djayness
    7 May 2008
    Cheers mate, If you need a waterblock done then thats easy enough :p PM me and we'll go from there!
