Scratch Build – In Progress Epic PC X Series 20.10.2010 Its over, finished, complete. Come one come all :)
Discussion in 'Project Logs' started by Djayness, 1 Feb 2010.
  1. Djayness
    Djayness phwupupupup
    7 May 2008
    The video gives alot more insight into the case progress at current!
  2. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    1 word - NIIIIIIIIIIIIIIIIIIIIICE :D
    Looking forward too seeing finished result!
  3. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Really coming together now dude. amazing how much more of a feel you get for the build from a video :thumb: oh and thanks for the honourable mention :)
  4. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    ^ im with him
    ive been watching for a while
    and you are really lucky to have a CNC machine at your disposal
    im envious
  5. imersa
    imersa Parvum Princess
    9 Apr 2009
    Video was really sweet. checked out the others of your previous work too. Good stuff!
    How much did the CNC set you back :O?
    loads of pennys?
  6. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Stunning work so far!
  7. Djayness
    7 May 2008
    No worries! Credit where credits due, the psu backplate works!
    Haha yeah loads of pennys, very much so.
    Thanks everyone! More to come!
  8. shakka65
    shakka65 What's a Dremel?
    17 Jan 2010
    This is some really mad modding. This is one heck of a beautiful case. I definitely like the watercooling ideas.
  9. Djayness
    7 May 2008
    Haha yeah lets hope it works. I have leak tested but I havent pressure tested it yet, I'm betting that glue will hold though....
    Where can I get different size O-rings for the waterblocks I want to build?
  10. LooZypher
    LooZypher Huh!? What!?
    4 Jan 2008
    This is Wicked!!!!!
    Nice indeed
    Sub'd
  11. Djayness
    7 May 2008
    The copper arrived from Perth, Perth being that place on the otherside of middle earth, just a bit down under from down under and a little west from Brisbane. I would have walked but the postage service is pretty reliable so I stayed put.
    It’s not thick, only 2mm of give but it should be fine. I am not sure how wide most o-rings are and indeed, I haven’t a clue where to get o-ring. If I can get 1mm thick o-rings then thats all good, I can rest easy. If not...then I will have to find a way to glue copper and acrylic together.....
    Lets hope it doesn’t get to that.
    Anyhow,I am in design hell at this very moment.
    Motherboards do not have alot of clearance and the compression fittings are kinda...fat.
    1mm engraved triangles should create a fair bit of turbulence I am hoping. I’m no engineer and its probably the best I can do with 2mm thick copper.
  12. stonedsurd
    11 Mar 2009
    I don't think you'll be able to get a good seal with o-rings on 2mm copper.
    But that design looks very sound otherwise. I see pissed-off machinists in your future :D
  13. Djayness
    7 May 2008
    Maths problem....NEED HELP
    My brain exploded thinking about this.
    The situation: The cutting tool slopes at 30 degrees, material is 2mm thick.
    Okay, so you have triangles and they in an array, equal spaces apart.
    If you put too many triangles in you lose depth
    If you put too few traingles in you lose surface area.
    At what point do you maximise surface area? The answer needs to be in the amount of triangles.
  14. Djayness
    7 May 2008
    Haha I am the one cutting it :p
  15. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Er... 2MM copper isn't going to be sufficient, methinks - it's going to flex as you screw it to the motherboard and then it's going to leak. Right over your CPU. You simply cannot put an O-ring in something that thin and expect them to seal, especially when under stress from the mountings. My guess as to the normal depth of a copper block is more like 5MM minimum; can't you get a bigger bit of copper?
  16. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Swiftech MCW-30s are 1mm copper and flat on the inside. For a chipset block, whatever you do will work just fine.
  17. Djayness
    7 May 2008
    I dont see why not. The o-rings on the bitspower fittings are 1.75mm when under no pressure so they should easily seal a .875mm thick cavity under pressure. The other .875mm goes into the acrylic thus creating the seal.
    The acrylic I will be using on top will be 10mm thick and hold the cavity of water. Although a soft metal, theres no way the 2mm will warp from two 3mm pressure cap screws.
  18. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    drill dimples, tap it... then solder it together. It won't leak if you do it right.
  19. Djayness
    7 May 2008
    What if instead of putting oring in the channel, I put just enough silicon?
  20. FrooP
    FrooP can I eat this?
    24 Oct 2007
    in any matter this wont work as you planned, 2mm copper will flex and youll get a "cave" under your chip/cpu/whatever, you may could use the 2mm copper as a base and then mill a delrin top which could hold the Oring and the retention module
