Scratch Build – In Progress Epic PC X Series 20.10.2010 Its over, finished, complete. Come one come all :)
Discussion in 'Project Logs' started by Djayness, 1 Feb 2010.
  1. stonedsurd
    11 Mar 2009
    But he needs restriction/turbulence to actually facilitate heat transfer (unless I totally misunderstood the diagram :p)
  2. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Its been thought of, but it seems too risky. Isn't there a little hole on top of the heat spreader?
  3. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Actually, if that splintered baseplate isn't gonna shed those splinters, that's more surface area than you could ever expect to create. You may have it perfect.
    It's hard, slow going learning to do this. You have some +rep from me for trying.
  4. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    EPIC MOD PERIOD!!! (sorry for yelling!;p) Stylish end very modern design! I like!!!!! :)
  5. Djayness
    Djayness phwupupupup
    7 May 2008
    Yeah but I dont want the splinters breaking off over time and having their own in loop adventure. I will have another crack at it :p
  6. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Wow, that's looking great. Wonderful craftsmanship!
  7. talladega
    talladega I'm Squidward
    18 Aug 2007
    maybe get them sandblasted to get rid of splinters?
  8. stonedsurd
    11 Mar 2009
    Exactly. Not worth the risk.
    This.
    But honestly, the best route would be to just take another crack at it. For a first try, those turned out fine, but I am sure you can do better :thumb:
  9. Jux_Zeil
    Jux_Zeil What's a Dremel?
    30 Apr 2009
    Surely you could lightly etch the CPU as it's surprising how much you can lap them by.
    I don't think so or when using extreme cooling the chip would fry because of condensation within the CPU. I don't think the dielectric grease wouldn't be able to stop it.
    Anyway, enough of the thread-jacking as Djayness is deffinitely wanting base plates.
  10. Djayness
    7 May 2008
    Yeah I bet you can tell I've never sleeved cables before. I was going off the XS cable sleeving guide and I still have much to learn!
    Im waiting on a whole heap of parts and I swear I spent at least 5 minutes going through how the cable management would work.
    The tube route is also a major headache that I havent figured out.
    Today is Valentines day so I think I'll give the mod a rest for a day. Also it's the first day of Chinese New Year and being half Singaporean and all, I cant work that day...traditionally :p
    dex2407 likes this.
  11. stonedsurd
    11 Mar 2009
    Er yeah :blush:
    You need better sleeving and to rectify that bunched-up sleeving on the topmost wire.
  12. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    That thing is nasty.
    This project definitely deserves MDPC sleeving.
  13. talladega
    18 Aug 2007
    Techflex also has really good sleeving, if you cant afford MDPC sleeving.
  14. Djayness
    7 May 2008
    Surely there is an easy way to get mdpcx without being in Canada or the US right?
    I might start searching for some in Aus, I thought what I had was tech flex :(
  15. stonedsurd
    11 Mar 2009
    I'm not sure about Oz but I was under the impression that MDPC-X had fairly reasonable shipping overseas. I've ordered to both India and the US from there and it really wasn't too expensive.
  16. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    MDPC-x.com should ship to Aus, i got some sent to the UK and it was only like £6 postage.
    Make sure when you sleeve that you stretch out the sleeving as tight as possible. If it is bunched up, the holes open up and you can see the cables.
    For white sleeving, i thoroughly recommend getting white electrical tape and wrapping each cable individually in it before heatshrinking it. It will look really white then.
  17. Djayness
    7 May 2008
    I have contacted Nils in regards to getting some sleeving in :p I can start concentrating on the other parts that need my attention now.
    Time for an update I think!
    Motherboard trays are so integral to everything in a computer yet they are usually an afterthought, something thats overlooked. Here is my attempt and making the ultimate motherboard tray :p
    Did a test fit and...it fits! Moving along....
    • Time for some visualisation.
    • The motherboard cover is painted black and gold with 1000 W across the side in Epic PC font.
    • The wiring is sleeved with mpdc-x black and curls like that to the atx point.
    • Water is running through the res and up into the tube reducer on the motherboard tray, its orange.
    • The motherboard is fully hooked up with my home brewed copper blocks.
    • I have a graphics card.....Its watercooled.
    Getting there, slowly but surely.
  18. Djayness
    7 May 2008
    Going to give the watercooling another chance.
    The nozzels should provide some turbulance into the block and the design should hopefully work out this time. Mist spray, multiple passes and some copper polish should do the trick this time!
  19. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    Can you post some more info on the blocks? When your talking about Nozzles are you talking about something like a Swiftech Storm design or like a HK 3.0 or like a Swiftech GTZ/XT/GT?
  20. Boxcarr
    Boxcarr Will use any tool available.
    3 Dec 2009
    If you are just using water for coolant i would suggest turning a hose on it.
    If you insist on misting though, I would not cut all the block at one time. Take breaks in between passes to allow the copper to cool down. This should keep the copper from "melting". A high speed and feed while taking a moderate amount of material at a time should keep the copper form splintering.
    Last of all, good luck! The build looks great!
