Scratch Build – In Progress Epic's Thermal Tower - Need suggestions for the loop route, help me! 20.05.2012
Discussion in 'Project Logs' started by Djayness, 30 Jan 2012.
  1. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Thats just soo beautiful :), Your cnc is doing very well :)
  2. Djayness
    Djayness phwupupupup
    7 May 2008
    Thanks Kosar :)
    Me and a mate of mine decided to have a go at sleeving with paracord. It's actually quite nice to work with and I've found some other decent uses for it as well around the home.
    I took the computer apart again for a final polish down, you'll notice some goodies that ASUS ROG sent through as well :)
    I've always wanted two copies of BF3 :p
    The 6990 will be watercooled :)
    That is one sexy motherboard :) I will be doing a full review of it once I get it up and running. Anyone know a RAM block for the dominators that will work either side of the dimms?
    Thanks to ROG and ASUS for their support!
    Razer
    EKWB
    Fraglabs
    Asus
    Republic of Gamers
  3. KoSoVaR^
    19 Dec 2010
    Thats some great eyecandy there! As for the dimmblocks you need two EK Ram Dominator x4's
  4. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Bitspower makes two-dimm blocks, as does MIPS and Aqua-Computer, though I'm not sure if all of those will work with Dominators.
  5. peteski
    peteski long live the pc
    8 Jun 2011
  6. Djayness
    7 May 2008
    Ah, I will most likely get some x4 dominators in from EKWB :p
    Thanks Pete :) It's nice new and shiney!
    I just reviewed it!
    If you want to be in with the chance to win an hour of custom work with us then just share this post on our facebook.
    Razer
    EKWB
    Fraglabs
    Asus
    Republic of Gamers
  7. Djayness
    7 May 2008
    I had today off. Significant things happen when I have days off.
    It's the base of the case and yes that's an EKWB radiator with S frame Noiseblockers. Besides costing a small fortune, S-frames are all nice and rubbery, the actual fan doesn't touch the frame and whilst on, you can't actually hear them.
    Time to reassemble!
    Ikea would be proud. Now I just need to name it something inspiring like "Lack". I have two of the "lack" tables from Ikea, great value because they inflate every year with moisture and it's almost like I'm getting a free size upgrade.
    Horrible photo although at the time I had some unique space constraints.
    360mm at the bottom, 360mm at the top and 6 Fans. Airflow is most certainly no issue here!
    Fraglabs will be selling our cases fully installed, anywhere in Australia :)
    Just waiting on some EKWB Dominator X4's, a top watercooled mosfet and a 6990 waterblock and backplate!
    Thanks to all the sponsors!
    Razer
    EKWB
    Fraglabs
    Asus
    Republic of Gamers
    peteski likes this.
  8. Metrodusa
    Metrodusa What's a Dremel?
    14 Jan 2012
    The screws on the right look awesome, where do you get them? And the same goes for the ones on the fans.
  9. Djayness
    7 May 2008
    I get mine here :p
  10. Metrodusa
    14 Jan 2012
    Shipping to Europe can be expensive, but they really look nice.
  11. KayinBlack
    2 Jul 2004
  12. peteski
    8 Jun 2011
    Again i will say god dam that board is sexy. Looking good mate loving your work 5 stars +rep :rock: :rock: :rock:
  13. KoSoVaR^
    19 Dec 2010
    I have a Bitspower Galaxy Freezer for my Chocolate Temptation project and i can recomend it, its a great block and tje finish is just awsome :), and they will fit better than the x4's
  14. Guest-16
    Guest-16 Guest
    Watching this one now :D:D :rock:
  15. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    looking good:thumb: mod on!:dremel:
  16. Djayness
    7 May 2008
    Oh well, X4's are on their way haha :)
    Cheers Bindi :p
    Modding on, new video! DON'T SUBSCRIBE TO MY YOUTUBE! DON'T DO IT! (reverse psychology :D )
  17. Djayness
    7 May 2008
    More stuff!
  18. Djayness
    7 May 2008
    Asus just ordered a Thermal Tower and I have just on 3 weeks to have it built, installed and ready to go. I will most likely spend two weeks redesigning the case from what I learnt on the original. Here we go!
    The hardware that's going in for Supanova!
    Watercolour!
    After a peel and a polish!
    Madly cutting the rest of the panels!!!!
    One sheet down, 5 to go!
    Check out the gear going into it :)
    Oh man....what a marathon.
    No sleep last night, worked all day and then finally at 1am, tis ready.
    Two weeks of redesigning and 4 almost solid days of cutting and building. CMONNNNNNN! *hewitt hand...thingy*
    Maximus Gene V, GTX680 :)
    Waynio likes this.
  19. Djayness
    7 May 2008
    Reserved
  20. Djayness
    7 May 2008
    Parting shot before it heads off to Supanova on the Gold Coast!
