Scratch Build – In Progress Epic's Thermal Tower - Need suggestions for the loop route, help me! 20.05.2012
Discussion in 'Project Logs' started by Djayness, 30 Jan 2012.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    :clap::rock: Things are looking up & up, congrats. :)
    stars & rep
  2. mav2000
    mav2000 In Training
    16 Oct 2010
    Wow, super work there. Are those panels aluminium or acrylic?
  3. Djayness
    Djayness phwupupupup
    7 May 2008
    Thanks Waynio :) This isn't finished yet, I still have the original Thermal Tower to work on!
    Polished acrylic, sand polishing single direction.
  4. Djayness
    7 May 2008
    Thanks once again to Asus :)
  5. skitzab1
    skitzab1 What's a Dremel?
    21 Apr 2012
    hi Dan cant wait to get mine
    can we put a little badge saying "thermal tower build #1 of 9999) or how ever many u plan on in the build run (are thay going to be a limited run ????)
    u and asus have the prototypes so plz plz :)
    im liking things about the first black one like the window iv been thinking on that a lot :)
  6. Djayness
    7 May 2008
    Yeah for sure, Just let me know what you want :)
  7. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    I only like the black version, the white Rog edition is not that good, the elements of it just dont conect and that big asus symbol and above the acrylic window dont combine... i like your other cases, but this white one could be improved...;D
  8. Djayness
    7 May 2008
    Each to their own :) I have a few more Thermal Towers on the way and yes, the one I am doing for myself is themed black and blue.
    Supanova yesterday and also had the Roar Grand Final! Watch the vid to see the Thermal Tower at the event and more!
  9. skitzab1
    21 Apr 2012
    i like it with the big window aswell :) the black
  10. Djayness
    7 May 2008
    Just did an overclocking guide and review on the Maximus V in the ROG Thermal Tower.
  11. Djayness
    7 May 2008
    My GTX680 review :)
  12. Djayness
    7 May 2008
    This build has been progressing but I just moved to Sydney to take up a job as a youtube presenter for Asus ROG Australia (not a bad job right!). At the moment, I'm not entirely sure what the best way to do the loop would be. Feel free to save the photo and reupload it with red lines where you believe the tubing should go.
    Waiting for the internet to be connected before I start doing some heavy photo uploading :)
    Oh and here's me on the Asus ROG Australia channel. Just launched it so sub and comment if you have time!
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    That's awesome, congrats Dan :clap: you definitely make a good presenter for the job mate. :)
  14. Djayness
    7 May 2008
    Thanks Waynio :)
    Any suggestions on the loop? This is what I have so far but I am open to suggestions.
  15. Metrodusa
    Metrodusa What's a Dremel?
    14 Jan 2012
    As I'm currently planning sth similar myself, I decided to go dual loop. Less cluttered and if you decide to use one of the EK links for graphic cards, you can route the piping anyway you like.
  16. Djayness
    7 May 2008
    I would have but the outlay of another pump/res was far past unwanted. Single loop with the surface area of 6 radiators should be fine.
  17. alain-s
    alain-s Minimodder
    12 Jan 2011
    Just need to place the pump somewhere.
    The order of the loop: Res, Pump, Rad, Mosfet, Ram, CPU, Ram, Rad, GPU, GPU, Res
    If u turn the Radiator in the bottom it will make the loop a little shorter.
  18. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Could be crazy and put in two loops? One for the Mosfet, Ram and CPU, another just for the GPUs? It would mean twice the complexity, but Overkill is Underrated, right?
  19. Mizugetsu
    Mizugetsu What's a Dremel?
    12 Aug 2008
    A single loop might work as I look at the above picture
    Pump>CPU >RAM(left)>MOSFET > RAM(right)Rad (bottom) > GPU>GPU > Rad (top)> reservoir
    I'll try and upload a picture when I'm not at work
  20. Djayness
    7 May 2008
    It actually turned out a lot like that although I have yet to test whether or not the pump head will be adequate.
    Meanwhile, I had a look at a card that is pretty hard to get a hold of right now.
