I have a small board that USB ports an eSATA port and a mic-in and headphone-out jack on it. I want to epoxy this onto my HAF922 so i can have some extra ports for my pc. The question is: What epoxy should I use to mount this on the inside of my case? Pic below.
Any two part epoxy resin will do the trick but a tidier job could be accomplished with metal brackets, or hot glue for a less permanent fixing that will still hold until you want to remove the board.
