Scratch Build – In Progress Erector Set WaterPlant - Aug 17: All operational!
Discussion in 'Project Logs' started by dacust, 12 Mar 2007.
  1. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    You may want to consider running the HDs and the chipset + ram on a separate loop as those generate about the same amount of heat compared to the CPU + Vid
  2. dacust
    dacust What's a Dremel?
    10 Mar 2007
    Cool, thanks. For a 3 loop, I figured 1. CPU, 2. GPU + RAM, 3 Chipset + drives. But for home use right now, the single loop seems fine.
  3. DarkLord7854
    22 Jun 2005
    Hmm, I think 3 loops would be overkill as the HDs themselves don't produce a ton of heat, and neither does the RAM nor chipset, compared to the CPU and especially the video card (which can easily hit 80 degrees Celsius), 2 loops, one for CPU/vid and the other for everything else should see you through.
    If you've got the hardware/tubing, try setting up a second loop like that and see the temperature difference (if any) :)
  4. dacust
    10 Mar 2007
    I agree. I am only thinking of 3 loops in case the hot boat requires it.
    I'll wait and experiment with a second loop while doing the Erector Set PowerStation PC.
  5. DarkLord7854
    22 Jun 2005
    You know what else you could do to reduce heat outputs? Mess with BIOS and lower voltages a bit, also start messing with MSCONFIG and cut out processes you don't need, check active process list and mark some for removal (like java update checker, adobe reader update, and so on), tweak windows and lower the memory usage, I've got mine down to 300mbs, lower PF usage, the less often the computer has to spin the HDs up, the less heat they'll produce, put power save modes in effect, like standby/hibernation. If you're not going to use the vid card for gaming, think about a cheap PCI card or something. I think I've got this old Radeon 9200 PCI card which is passively cooled by this puny heatsink, barely produces any heat. Also consider underclocking components
  6. dacust
    10 Mar 2007
    Good ideas for when I do the marine computers. Since they will be 12v, the power consumption will be an additional consideration, which your ideas will address as well as the heat.
  7. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    Great work, dacust. Love the erector set waterplant.
  8. dacust
    10 Mar 2007
    Thanks! I'm now working on the PC. Nothing to start a thread with, yet. Just making mockup parts out of foam core for the components.
  9. Harrybo
    Harrybo GAMER
    21 Aug 2007
    Wow that looks awsome, Hope it all goes well
  10. dacust
    10 Mar 2007
    Thanks! I'm out of town the next two weekends, but hopefully during some evenings I'll get far enough along to start the new log.
  11. Guest-23315
    Guest-23315 Guest
    That looks great.
    Take it your a bit of a Koolance fanboy then?
  12. dacust
    10 Mar 2007
    Well, it just seemed to work out that way. They were the only people that had a graphics cooler for my card that did both sides. And what seems to be the best ram cooler. And disk coolers. And then for the CPU and chipset, there's seemed to be just as good. I only wish they didn't use 1/4" on there specialized coolers.
    So I guess I've turned into a Koolance fan, but that won't stop me from looking at other stuff.
  13. dacust
    10 Mar 2007
    Finally ran Prime95. This is after running all day while I was at work.
    Code:
        Sensor Properties:
          Sensor Type                                       Abit MicroGuru  (ISA E0h)
          GPU Sensor Type                                   National LM63  (ATI-I2C 4Ch)
          Motherboard Name                                  Abit AV8 / KV8 Pro Series
        Temperatures:
          Motherboard                                       35 °C  (95 °F)
          CPU                                               41 °C  (106 °F)
          PWM                                               49 °C  (120 °F)
          GPU                                               35 °C  (95 °F)
          GPU Ambient                                       42 °C  (108 °F)
          WDC WD2000JD-00HBB0                               31 °C  (88 °F)
          WDC WD5000KS-00MNB0                               34 °C  (93 °F)
          WDC WD5000KS-00MNB0                               33 °C  (91 °F)
    This is about 30 seconds after shutting Prime95 down. The CPU was down to 37 less that 5 seconds after shutdown. The PWM took a little longer, which makes sense. Now, about 5 minutes the PWM is back down to 43.
    Code:
        Sensor Properties:
        Temperatures:
          CPU                                               37 °C  (99 °F)
          PWM                                               47 °C  (117 °F)
          GPU                                               35 °C  (95 °F)
    So, I am VERY satisfied with the performance so far.
    I've done a little more on the Erector PC, but still nothing to start a thread with.
  14. Azayles
    Azayles Minimodder
    6 Jan 2008
    Hi dan. I'm really loving this mod so far, can't wait to see it in completion :D I'm new to this forum, just wanted to join to say hi and get update notifications :p Keep up the great work :)
    Chris
  15. TapperSwe
    TapperSwe What's a Dremel?
    20 Nov 2006
    Great to see that all is working fine :thumb:,looking forward to see some progres on the PC ..
  16. dacust
    10 Mar 2007
    @Azayles and Tapper - Thanks for the comments. I haven't worked on it in quite a while. Been working on the boat, mainly. On the computer, though, I added a raid controller and two more 500GB drives so with 4 500s in RAID 5, I got 1.5 TB Raided and 400 GB non-raid. The 1.5TB is full, so I gotta expand :eeek:
    The WaterPlant has been running just great all this time. I add water about every two months.
    I'll start back some day, but not for a while. Gonna go to school and get my captains license this Spring.
  17. TapperSwe
    20 Nov 2006
    I got a 250 gb hd and its only half full, u have used up 1,5TB how do u do that? lol, anyway good luck geting your licence,hope you wont be away for to long.
    Regards.
  18. Azayles
    Azayles Minimodder
    6 Jan 2008
    1.5 TB full Dan? omgg. you must have an absolutely huge MP3 collection, or love to DL loads and loads of movies :D With a terabyte of space, that's what's I'd do ;)
  19. Guest-23315
    Guest-23315 Guest
    1.5TB?
    Porn.
  20. Brett89
    Brett89 Minimodder
    15 Dec 2005
    Quoted for truth. Looks great.
