Peripherals Ergonomic/Dvorak/Pinkie Friendly Keyboards
Discussion in 'Hardware' started by sotu1, 26 Jul 2013.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Hi guys,
    I'm on the hunt for a new keyboard. Basically I use my left pinky on the CTRL button a lot (gaming and daily work) and I'm now feeling the effects of RSI/Carpal Tunnel Syndrome in that finger.
    Does anyone know any other alternatives to the QWERTY keyboard or a way to save my little finger from being broken by the age of 30?
    Ta!
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Make me smile to see Dvorak, I don't use it myself but I tend to use it more as a prank in the office.
    Set Dvorak, then set system language to Russian. This is the utter last resort to kill all other pranks played on me.
  3. GeorgeStorm
    16 Dec 2008
    You could reassign the key maybe?
    What keyboard do you currently use?
  4. Lance
    Lance Ender of discussions.
    6 May 2010
    What about a HHKB lite?
    It has control where CAPS is, and caps is a fn tab, that way you don't use your pinky so much.
  5. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Problem is I also use my pinky for shift, cut and paste short cuts...everything. My pinkie does a lot of work! so basically It's getting knackered out. I need to stop using it altogether! I'd prefer it if the space bar was divided up into space, shift, alt and ctrl and put my thumbs into a bit more use....
