Other Ergotron HX
Discussion in 'Tech Support' started by User-sam, 1 Mar 2026.
  1. User-sam
    User-sam When in doubt, follow your nose.
    10 Apr 2010
    Hi all,
    I’m hoping for a bit of advice.
    I have an Ergotron HX monitor arm (white), but unfortunately during a house move I’ve misplaced the desk clamp. I still have the arm and base, but without the clamp it’s obviously unusable.
    I’ve already contacted Ergotron directly to see if they can supply just the clamp as a spare part. If that doesn’t work out, does anyone know:
    • Where I might be able to source a genuine replacement clamp?
    • Whether Ergotron clamps from other models are compatible?
    • Or if there’s a reliable third-party or alternative mounting solution that would work safely with the HX?
    The arm itself is in good condition, so I’d really like to avoid buying a full replacement if possible.
    Any suggestions or experience would be much appreciated.
    https://ibb.co/twQB65h6
  2. sandys
    sandys Multimodder
    26 Mar 2006
    It is entirely possible that I have a couple of those in the attic, I used two of them for an elaborate dual screen entertainment centre in my caravan where I removed the clamps to screw the arms bases into a custom standbase I made, so will have two clamps that have never been used, just don't know if I threw them away in a loft clear out.....
    But it'd be easy to make something with some bits from DIY store I'd imagine.
  3. sandys
    sandys Multimodder
    26 Mar 2006
  4. User-sam
    10 Apr 2010
    "elaborate dual screen entertainment centre in my caravan" - I have so many questions regarding this sentence!
    That's a shame, but thanks so much anyway.
  5. sandys
    sandys Multimodder
    26 Mar 2006
    Remembered I used one in Covid for the attic office
    It's a. Simple clamp setup quite easy to reproduce, reckon that'd be the same as what is needed on the HX. I could see the other up there but so many boxes
    Yaka and Arboreal like this.
  6. Yaka
    Yaka Multimodder
    26 Jun 2005
    bit late but i haven't been online much past few months
    just checked under my desk, i have the amazonbasics one which is a "rebranded" hx, got delivered in ergotron packaging an it looks like it the same one Sandy has
