Motherboards Error in device manager
Discussion in 'Tech Support' started by Flak, 4 Jun 2011.
  1. Flak
    Flak Member
    11 May 2011
    Not sure if this is the correct prefix for this question, but here goes. I have a new system with an Asus p8p67 pro mobo and Win 7 64 bit OS, all works well except for an error showing in device manager under "other devices" as "unknown device" the location is Port_#0007.Hub_#0004 and the device status is "The drivers for this device are not installed. (Code 28)"
    The location path for the device is "PCIROOT(0)#PCI(1D00)#USBROOT(0)#USB(1)#USB(7)" I have tried updating the driver but the troubleshooter says no drivers are available! I assume that this error refers to a USB port or ports?
    What can I do to sort this please?
  2. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    Unplugged all external devices, installed all the motherboard drivers?
  3. Flak
    Flak Member
    11 May 2011
    Yes, all mobo drivers installed. only USB peripherals connected are a printer and mouse/keyboard both of these are working properly.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    uninstall the device with the error, reboot windows and it should reinstall driver
  5. tehBoris
    tehBoris New Member
    30 Jan 2011
    Probably an integrated device on the mother board is connected via USB. Does the motherboard have bluetooth or wireless built in, does it have any other 'non-standard' feature like that?
  6. Flak
    Flak Member
    11 May 2011
    yes mobo does have bluetooth built in, and I cant see it shown in device manager!
  7. tehBoris
    tehBoris New Member
    30 Jan 2011
    This is most likely the answer then, find the Bluetooth drivers and install them, or don't worry about it if you aren't going to use it.
  8. bulldogjeff
    2 Mar 2010
    I was just thinking that. If everything is working ok then you can just ignore it.
  9. Flak
    Flak Member
    11 May 2011
    can I disable it in device manager so as to get rid of the yellow warning?
  10. bulldogjeff
    2 Mar 2010
    The only way to do that is to delete it. But I wouldn't as you could end up starting a knock on effect and just end up with a right mess. I'm not sure if diabling it will get rid of it, but it won't do any harm to try it. You could try a program like drive genius to find it and update it for you.
  11. tehBoris
    tehBoris New Member
    30 Jan 2011
    Might be able to turn it off in the BIOS.
  12. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    if its an onboard device, the driver for it should be on the driver disk that came with the hardware. insert the disk and choose update driver. if not, right click and go to properties, details, does it list a hardware id? if so you can look it up that way.
  13. chris66
    chris66 Member
    10 Jan 2011
    I had exactly the same problem when installing the mobo drivers for my step-son's PC with the same Asus motherboard. It was the bluetooth drivers that were missing. I didn't use the automatic install of all software and drivers on the disk, as Asus, rather stupidly bundle anti virus software in with the main driver install package - which I didn't want (use Microsoft security essentials)
  14. Flak
    Flak Member
    11 May 2011
    Thank you all for your help and ideas, the hardware ID is:
    USB\VID_0CF3&PID_3000&REV_0200
    I have googled it and it confirms this is the bluetooth adapter and the drivers arn't installed. I have the mobo disc can I just install the drivers from the disc whilst in Windows?
  15. SuicideNeil
    SuicideNeil New Member
    17 Aug 2009
    Should be able to, just select the bluetooth driver from the list of items on the disc's menu, rather than clicking 'install all'. Might just need to reboot afterwards.
  16. Flak
    Flak Member
    11 May 2011
    Installed the bluetooth drivers from mobo disk, error gone! Thank you all for your help!
